Question about Royal Scrittore Manual Typewriter
Can't remove old ribbon to replace
How do I remove the casing to replace the ribbon?
  • 43 Answers
Some have latches under on both sides, other the top just pulled up.
Posted on May 02, 2014
Please can you send me a picture of how to install the ribbon in to the Remington Standard No.12 typewriter. Or tell me how to thread the ribbon.
Hi, first of all there is no picture diagram for this and this method am giving you is what has been used to install ribbon on different typewriters.
  • Remove the existing ribbon. Note the path that the ribbon takes as it goes from one spool to the other.
  • Roll the ribbon entirely on to one of the two reels if your replacement ribbon didn't come with a take-up reel. If your new ribbon has a take-up reel, skip this step.
  • Attach the end of the new ribbon to the take-up reel if your new ribbon doesn't already have one. In most cases, there is a sharp arrow shaped piece on the reel. Use that arrow to penetrate the ribbon and make a few winds of ribbon around the take-up reel.
  • Slip the take-up reel on the take-up spindle on the right side of the typewriter. Align any tabs designed to turn the reel to move the ribbon during typing.
  • Feed the ribbon through the path you noted when removing the old ribbon and place the main ribbon on the spindle. Give the take-up reel a few turns to make sure the ribbon moves freely through the typewriter mechanism.
Jan 18, 2011 | Office Equipment & Supplies
How do I install a new ribbon on the smith corona electra 220 typewriter and where can I find a manual for this?
This is a sensitive installation, i will advice you follow and adhere to the installation instruction from the the manual of you unit, you can search for the manual at manualsonline.com.
Take care.
Oct 23, 2010 | Smith Corona Office Equipment & Supplies
Check ribbon
Remove the ribbon along with its fitting from the printer and fix it back. Replace the ribbon, if in case worn out or used excessively or stuck within.
I hope this fixes your problem.
Jul 09, 2010 | Tally T2250 Matrix Printer
Printing quality is very poor
The print quality of dat matrix printers depends upon the printer ribbon. If the ribbon is old or worn out then the print will be very light. In this case replace the ribbon.
Dot matrix printers are very old technology and I suggest you get a Inkjet printer or a laser printer.
Dot matrix printers cannot match the print quality of Inkjet and laser printers.
Jun 04, 2010 | Office Equipment & Supplies
Nikon L11, how to replace the LCD screen?
is very easy. you will need only a cross screw driver. This operation should take no more then 15 - 20 minutes
May 31, 2010 | Nikon Coolpix L11 Digital Camera
How to open to change ribbon on a Canon mp25dv
Remove the paper tape by pulling it back out of the calculator.
Feel along the back of the calculator right below where you insert the paper tape for a ridge. Gently lift up on this ridge and a plate will lift out of the machine exposing the ribbon.
Make a note to yourself as to how the old ribbon is in the machine before removing the old ribbon. Just gently lift straight up on both of the spools and the ribbon will lift out of the machie.
When you insert the new ribbon make sure that the ribbon is feeding off of the back side of both spools. You can use a small screwdriver or toothpick etc to position he new ribbon to keep the ink off of your fingers. Make sure the new ribbon feeds around the plates on both sides of the machine and it fits behind the roller that has all the numbers on it and that the red portion of the ribbon is on the bottom.
Take the plastic plate that you removed first and insert the tabs in the front underneath edge of the case on the front and gently push the back side of the plate straight down till it smaps into place.
Refeed the paper tape back into the machine and you are finished!
Hope this helps.
Apr 20, 2009 | Canon MP-25DV Calculator
Replacing the lcd screen on casio exilim ex-z77
the LCD will have a ribbon cable going around to the front and it will also have two small wires red and black for the back light. those have to be desoldiered and the ribbon cable unplugged and gently removed. I repair these camera all the time and this unit is a pain. If you do not fill comfortable replacing the parts you can go to www.digitalcamrepair.com if you need further assistance.
Sep 30, 2008 | Casio Exilim EXZ75 Digital Camera
LCD screen replacement
www.buy202.com they have them for under 40 with free shipping
Sep 08, 2008 | Kodak EasyShare M853 Digital Camera
How to replace LCD monitor/screen in an Olympus C5050 camera
Easy, remove the 9 screws that hold the rear case and pull the case apart,.remember there are 4 screws under the hotshoe base and 4 under the memory door and one under the USB cover. You need to pry and slide the hotshoe base back with a slim screwdriver and youll see 4 screws, remove the rear ones. There will be 2 ribbon cables attached to the rear case, the LCD and the buttons. These pull out carefully with gentle pressure. The LCD can be removed with screws and another ribbon cable connector that needs to be unclipped and then removed. replace LCD, Put it back together and make sure the ribbon cables are fully seated. Good to go.
May 06, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
CD Drive replacement
thake out the screws on the bottom of the lap top then there are 3 very small clips holding in the keyboardone at the control key one at the space bar and one at the down arrow key push thes back and lift out the keyboard it has a cable conector on it so be carefull then you will see two screws holding in the cd drive and a ribbon conector remove it by pushing forward the small ribbon holder then remove the drive
Oct 29, 2007 | Samsung X05 Notebook
Royal Scrittore Manual Typewriter Logo
65 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
