Question about Panasonic VIERA Televison & Video
Ghosting image - VIERA Panasonic Televison & Video
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
Ghosting is caused by wires touching. The signal gets cross-talk. Separate the wires in back, and it is an instant fix, easy.
Posted on Nov 27, 2014
  • 3 Answers
SOURCE: Ghosting on LCD
He may just be giving up too soon. Again, does this happen on every channel no matter what is plugged into it?
If replacing the cables doesnt help, try giving sony tech support a call and see what they suggest. It wouldnt hurt to get a professional opinion. Plus if your warrenty has expired and they offer to repair it at a cost, im sure it will cost less than a new 40" TV
Not sure what country you're in so go to the website below and choose your country then look for their contact email or phone number. I'm sure they will be helpful, thats what theyre there for.
http://www.sony.com/
Have your TV model number (usually on the back of the set) and details of the fault handy. They may also ask where you purchased it from.
Posted on Feb 10, 2009
vinnyq
  • 157 Answers
SOURCE: Ghosting and very dark mostly orange screen
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Posted on Oct 05, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: ghosting on one side of screen on start up, then goes away
The T-con board failure or LVDS cable connection loose may cause the problem, you can try to reconnect the LVDS cable first.
Knowledge obtain from: Real case of repair by myself.
Posted on May 09, 2010
  • 18 Answers
SOURCE: ghosting image on samsung led tv in 3d mode
well i think i have got something for you...try the link samsung lcd tv ghosting
Posted on Jan 10, 2011
SOURCE: Multi-colored vertical lines fade in
Tab Bonding Issue. I too have had this problem with the very same model, it is most often improperly diagnosed as a t-con board issue by most who just want to provide an answer for the sake of there own ego at various forums. This is a manufacturing defect. I have been dealing with Samsung for over a month now and have been offered a replacement model of lesser quality(LN40C650L1F) at a prorated cost of $300.00 to me which I have not accepted as of yet. My TV began having this issue almost exactly 1 year beyond warranty period. Typically it will only happen when TV is cold(if temp in room falls to approx. 68 deg or lower). When cold due to naturally occurring shrinkage as with anything, the tab bonding contacts to the screen are broken and therefore gives you 3 thin horizontal lines across separating the screen into four quadrants vertically and blurry details of everything including channel info, menu info, etc. It goes away after several minutes of warm up time, as the unit warms up expansion of the panel resumes and contact through the defective tab bond is made and picture is back to normal. A quick test to determine this is if you gently squeeze the bezel(frame) around the panel at the top left corner approx. 2 to 4 inches from the corner(this is where the defective tab is located for this particular problem) the problem will go away until the unit is turned off and has ample time to cool off again. When you squeeze you are effectively forcing the tab bonding back together and contact again is made. Another way to diagnose would be to turn your thermostat in house up above 72 degrees or so and wait a few hours for the TV to acclimate to the temp(expand) .This is why if left alone for a few minutes to warm up the problem disappears. Consequently people who keep there homes on the warm side, say above 70 deg. don't often see this problem, but the more heat-cool cycles the units go through the more likely this problem will rear up its ugly head.I believe this defect will pop up eventually on all samsungs produced with the same tab bonding method or materials that were used for however long they were manufactured that way. Naturally everything moves(expands and contracts) through heat-cool cycles but proper engineering methods or materials should prevent something like this from happening for at least, lets say 10 years, the average life expectancy one would expect to get out of a $1500.00 or more purchase depending on screen size. Common sense would dictate larger screens would be more prone to this problem due to more movement and smaller less prone. Unfortunately there are numerous tab bonds all across the top of the screen(panel) and different ones affect different functions of the operation of the set, therefore there may be many other various problems people may be experiencing with there samsungs due to a failure of one of these tab bonds. They are often erroneously diagnosed as circuit board failures due to laziness on the part of the tech. I would recommend to anyone experiencing intermittent or any problems to gently squeeze all along the top of the bezel to locate a defective tab bond. As for dealing with Samsung, all I can say is good luck, it is difficult to reach their corporate office and even more difficult to get a resolution. I would gladly join in any class action lawsuit if brought about as the one regarding their capacitor issue disappeared once they sought to start addressing the issue and this was only after an absurd amount of complaints to the NJ BBB and consumer affairs websites. I think they realize that they have a huge problem with most models manufactured in the last 3-4 years(primarily due to using cheaper components as a cost reduction/profit boosting solution) and as with any large corp., are not willing to issue any recall as it is cheaper to just deal with angry customers on a case by case basis, very unfortunate for them as their sales will suffer terribly because most people research on the web before making major purchases in today,s world and thank god for that.
Posted on Feb 27, 2011
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Tip
The ghost image of the print is printing on the paper with the orignal print ?
Ghosting is a condition where theimage prints properly, but a much lighter copy of the image also printselsewhere. This can be due to a problem with the power outlet that is supplyingpower to the printer. Check the power outlet by plugging in a different printerto see if the same results occur. Ghosting can also be caused when consumableprinter parts (such as the drum or imaging kit) are near the end of their life.All of the consumable parts in a printer are rated for a certain number ofpages. Once a printer gets near that magic number, you'll need to replace thoseparts to eliminate ghosting.
This will help. good luck.
on Mar 05, 2010 | Office Equipment & Supplies
Sony bravia 52 kdl xbr ghosting
Michael, does the ghosting go away of you tap the set? Or if you turn off the set and let it cool off and turn it back on, is the ghosting still here? One of the most common causes of ghosting or double image problem is due to a defective LCD panel tab. Sony's are known for this problem. I would recommend getting a diagnoses done on the set to be sure. If it turns out to be a LCD tab problem, the only true fix is to replace the panel.
Nov 24, 2012 | Sony BRAVIA Televison & Video
Only on color printing am I getting ghosting of the images. How can I adjust this?
hello,when i see one color dusting, ghosting i usually change that color drum unit.If multi color ghosting probably the transfer belt cleaner blade.thanks don
Nov 10, 2009 | Canon imageRUNNER C3200 Copier
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
Ghosting image on canon c3220
Suggest to check the transfer unit. Especially the transfer cleaning blade..
Jun 12, 2009 | Canon imageRUNNER C3220 Color Copier
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Ghosting image after 3 years of perfect operation
ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Aug 11, 2017 | Hyundai ImageQuest Q995 19" CRT Monitor
Televison & Video Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
