Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
The chuck on the dewalt impact driver does not hold the bit holder in
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
If you go to dewaltservicenet.com you can enter your model number to see the parts breakdown. It can be tricky to get the retainer clip off and on but the rebuild of the bit holder is easy other than that. The spring and the steel ball are all that usually need to be repalced. Hope that helps.
Posted on Apr 22, 2014
Gigatech
  • 259 Answers
SOURCE: dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Posted on Mar 05, 2008
SOURCE: How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
Posted on Jan 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: got a broken drill chuck i cant get off (Dewalt)
first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
Posted on Jul 02, 2009
SOURCE: removing the dewalt DC925 'rohm' chuck
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Posted on Oct 18, 2009
SOURCE: problem with the chuck
Had the same problem on mine. Remove the chuck, then remove the snap ring on the back of the chuck( carefull, the housing will fall out once the ring is removed), on the side of the chuck you'll find a cam and small odd shaped spring held in by two cylender pins, on mine the spring had a gap in it and I just spread the gap to about twice the size in was and put everything back together and it has worked fine ever sence. Hope it works for you.
Posted on Dec 16, 2009
DeWalt 20 V impact. Driver ejects occasionally. Locks in correctly to start then after limited use, bit holder falls out.
These are known for the spring in the nose (#12) to fail.
Using an o-ring pick or small screwdriver remove the hog ring on the end of the bit holder (#17).
Slide the washer, spring, and sleeve off (Be careful not to lose the small lock ball)
The spring that pushes the lock ball forward (#12) is usually the culprit.
Reassemble in reverse order DeWALT DCF886D2 20V Impact Driver Parts
Dec 06, 2016 | Dewalt Drills
Screw driver bit stuck in chuck of impact driver.
a tough one If can't get hold of it you may be screwed LOL
getting that rammed in the chuck is very hard to get out even if can get a grip unfortunately you can't beat it out you would do more damage And no lubricate is going to help because it was tightened down. Hope someone can help you in this otherwise may have to replace the drill
Nov 06, 2014 | Makita TD090DW 10.8V Compact Li-Ion...
I'm looking for keyless chuck to makita btd 140
The Makita BTD140 is an impact driver that has a hex-drive anvil and bit holder assembly, it does not have a keyless chuck accessory. There are some aftermarket chucks with hex shanks on them to put into impact drivers but I've seen very few that hold up.
May 29, 2014 | Makita Drills
Dewalt dcf885 will not lock the bits in
It could be the little spring at the back of the chuck sleve is broken ot one of the locking balls is missing.
Apr 01, 2013 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
Remove the chuck dc970
I'm assuming you have a DCD970 as DeWalt doesn't have a DC970 and the DW970 is an impact driver. The chuck on your drill is a new design that doesn't have a lock screw inside the chuck, they are put on very tight with lock-tite to hold them on. They are made to be taken off with a special chuck holder and vice jig that only service centers have. The allen wrench method used on older chucks won't work as the chuck will just loosen when you hit the allen wrench. I have on occasion removed one by doing the following: Turn the chuck fully open then secure it in a vice with the drill straight up. Holding the drill body and using the handle for leverage, turn the drill counterclockwise, as you are looking down on it, with steady, strong pressure. If the chuck breaks free it will spin off easily. If you are at all afraid you may break the handle you may have to take or send it to a service center to have it removed.
Mar 07, 2012 | Dewalt Drills
Have a screw head stuck in the chuck .. it was a small bit and now wont pull out.... help
Just took apart a DeWalt, the chuck has a left hand scew that holds chuck in place, may be the problem
Jan 20, 2011 | Dewalt DW056 18 Volt Cordless Impact...
I put a short bit into my dewalt impact driver and now i cant get the bit out
Switch to reverse and driver mode hold tight the chuck then run the drill just to jack it... be carefull the keyless chuck plastic that release is easy to lose its grip to the steel so be patient. goodluck!
Dec 12, 2009 | Dewalt Drills
Jan 04, 2009 | Dewalt DW0521 Quick Connect Impact Driver...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
240 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
