Question about Nokia Asha 201 Blue Unlocked Dual-Band GSM Qwerty Cell Phone
Error rundll32 hardware malfunction rundll32
    New Friend:
    Problem Solver:
  • 6 Answers
Rundll32.exe is a process that allows dynamic link libraries (DLLs) to be executed. It is used to run DLLs and replace its libraries in the memory. Many system DLLs contain entry points for external use, including the control panel, as well as Shell32.dll. Solve Rundll32 exe Error How to Fix Rundll32 exe Not Found Error Fix EXE...
Posted on Dec 23, 2014
    Producer:
    Uploaded 30 video answers.
  • Nokia Expert
  • 309 Answers
At pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Posted on Jul 06, 2014
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Tip
How do I fix rundll32.exe on Windows XP?
Rundll32.exe is an important process for the Windows operating system. The process rundll32.exe take the dll file and put their libraries in the system memory. Without this process, the computer should be unstable and very slow.<br /><br />The process runs from your system directory C: \ Windows \ system32. If it executes or runs from elsewhere is most likely a virus or a Trojan. You should scan your computer immediately with a virus scanner. Viruses using the name rundll32.exe are W32.Miroot.Worm. Backdoor.Lastdoor and Trojan.StartPage (among others).<br /><br /><span style="font-weight: bold;">Fix rundll32.exe</span><br /><br />If a virus, such as Netsky, destroys rundll32.exe or, if for any reason, your rundll32.exe is corrupt or is accidentally removed, you must do the following:<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Find rundll32.exe DC system</span><br /><br />Check if you find a copy of rundll32.exe in the folder C: \ Windows \ system32 \ dllcache or in C: \ Windows \ Service Pack Files \ i386. If yes, go ahead and copy rundll32.exe to the system directory C: \ Windows \ system32<br /><br />If you can not find a copy on your system, try to locate the file on your Windows installation disc. Finally, you just reinstall Windows. It would be time consuming, and you may lose all your data. So what would be the last resort.<br /><br /><span style="font-weight: bold;">First, run a system repair tool to fix rundll32.exe</span><br /><br />There are various tools on the Internet that scan, analyze and fix your computer. In addition to solving your rundll32.exe these tools to remove all registry errors, remove invalid shortcuts and duplicate files, repair DLL files, and remove the errors start-up and running.<br /><br />
on Mar 07, 2011 | Computers & Internet
Rundll32.exe problems
check it for viruses . It's a common problem when your windows files are infected. (and pray to be that because the other way it's your hardware -hdd or ram)
Mar 17, 2010 | Microsoft Windows 2000 Professional Full...
In windows vista ultimate 64 bit. most of the items in my control panel will not open up. I get this message. c:\windowssystem32 undll32.exe file name or extension is to long. can you please help me. jim
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } hi
The rundll32.exe process is responsible for running DLLs and placing its libraries in the memory. The rundll32.exe process is known as a command line utility program, and it performs its embedded functions along with the rundll.exe file. Rundll32.exe works by invoking a function that is exported from a specific 16-bit or 32-bit DLL module. However the only DLLs that you can call with the rundll.exe and rundll32.exe files are the ones that are only specified to be accessed by these processes.
The rundll32.exe file operates by parsing the command line. The specified DLL is then loaded through the function LoadLibrary(). Afterwards, from the function , it gets the addresses through GetProcAddress(). The command line tail is passed when the is called. Next, the DLL is unloaded upon the return of . Finally, the rundll32.exe file exits.We strongly recommend that you run a FREE registry scan to identify rundll32.exe related errors.
if you have any question or any futher assistance you can get back to me on fixya for same
thanks
techbuddies
Oct 25, 2009 | Microsoft Windows Vista Ultimate Edition
Rundll32.exe
hi
rundll32.exe error appears when there is the virus in your system.If you want to solve this problem you have install new antivirus.
IF you want any help just visit me--------http://techbuddies-robin.blogspot.com/2009/06/free-computer-related-technical-support.html
Jun 19, 2009 | Computers & Internet
How to fix rundll32.exe-Application Error The instruction at &quot;0x009a068f" referenced memory at ''0x009a068f''.The memory could not be ''written''.Click on OK to terminate the program Click on...
It all depends on where the file is located.
The rundll32.exe file is located in the folder C:\Windows\System32 is a system file . In other cases, rundll32.exe is a virus, spyware, trojan or worm! .
Jun 04, 2009 | Computers & Internet
I have a rundll32.exe problem
Sounds like rundll32 got currupted by the virus, this is not uncommon. Perhaps you should locate a good copy. This site seems to have a good tutorial on how to do that:
http://ezinearticles.com/?How-to-Fix-Rundll32.exe?&id=913723
Good luck
Mar 13, 2009 | Computers & Internet
Rundll32 Error
copy rundll32 from someother vista laptop and replace yours.
May 24, 2008 | Computers & Internet
Nokia Asha 201 Blue Unlocked Dual-Band GSM Qwerty Cell Phone Logo
161 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
