Question about Bosch AQUATAK 150 PRO X Pressure Washer
Bosch AQUATAK 150 PRO X Pressure Washer - Bosch AQUATAK 150 PRO X Pressure Washer
2 Suggested Answers
biggn316
  • 16 Answers
SOURCE: I have a Bosch Aquatak 115 plus pressure washer that has a blockage on the inlet. I suspect some small particle in the water supply has caused the problem as it occurred in the middle of a job. I wa
need to clear out your total inlet system and flush the pump out if needed and install either inline filter or screen
Posted on Oct 17, 2012
What is the quantity & the type of oil of Bosch Aquatak 10 pressure washer? Thanks
The link has changed in the meantime i see
You can use every EP zinc-free hydraulic oil what you want for it PERLUS ZF46 is a very good alternative
Jun 19, 2016 | Garden
Shampoo will not come through
remove pressure nozzle or use low pressure nozzle only for shampoo
Apr 20, 2014 | Bosch AQUATAK 150 PRO X Pressure Washer
Not using shampoo
use nozzel with big hole or open nozzle up if adjustable
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
We have a bosch aquatak click 125 pressure washer. Could you tell us how to rewind mains cable into machine, normally it goes back on its own. Thanks
Try pulling it towards you and then letting go. Sort of like an old vacuum cleaner cord. It will probably click and then retract.
May 07, 2011 | Garden
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
Bosch AQUATAK 150 PRO X Pressure Washer Logo
41 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
