Question about Panasonic Lands Phones
Panasonic KX-TCD515EM Dect Base Station
Hi. I need to reset the pin number on my base station without having any phone registered to it. I can only see four recessed contact points on the underside of the base - no reset holes or buttons at all. Anyone any ideas? TIA, Dave
  • Dave McCreath
    Dave McCreath Apr 22, 2014
    Solved. Follow the instructions on page 52 of the KX-TCD505EM manual to change the handset PIN (even though the intention is to reset the Base Station PIN). Change the PIN on the handset to " *7000 " (note the * before the 7), thsi will reset your Base Station AND Handset PIN to *7000. You can now register the handset to the base station using *7000 and change the PIN to whatever you want (in my case back to 0000). Don't forget to reset the handset PIN back to whatever it was.
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
SOURCE: ATT 5840 Base reset code/procedure
document.write(parent.prscreen) Try this to get it working. Relocate the handset(s) closer to the main base.
Check for any lights on the base including charge, intercom, and channel lights (if applicable to the model).
Re-cradle the handset on the base for 15 seconds. Lift the handset and press PHONE.
Unplug the AC adapter from the main base unit and take out the battery from the handset. Leave it unplugged for 15 seconds. Plug the handset battery in and re-cradle the handset. Plug back the AC adapter in and wait for 15 seconds.
Try to de-register the handsets by following the steps below:
1. Using the soft keys on the base located below the base screen, press MENU
2. Press the down arrow once until BASE SETTINGS is highlighted.
3. Press the OK soft key.
4. On the base, press MUTE 3 times and FLASH twice. This will
deregister the unit.
Below are steps on how to re-register the handsets:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Other products that use the 5.8GHz band can interfere with the use of this phone. These products or equipments include: radio towers, page towers, cellular Phones, other 5.8GHz cordless phones, intercoms, or monitors. If any of these are in the area, they may interfere with the performance of the phone. Try relocating the phone.
Video displays, Televisions or Personal Computers can cause
interference on the phone if it is plugged in electrically with one of this equipment (typically on a power strip or extension cord). Please relocate the phone to an AC outlet without any other major appliance plugged in.
You can also relocate the base to another room.
Relocate the phone out of the kitchen area. Appliances may cause interference.
If the charge light does not remain on, clean the handset and base charging contacts using a pencil eraser. If it comes on after cleaning the contacts, you may need to charge the unit for 10 hours.
Make sure that the AC power cord is securely plugged into the base. If unsuccessful, plug the unit into a different known working outlet or turn on the switch on the power strip.
Posted on Apr 30, 2008
  • 9 Answers
SOURCE: Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Posted on Dec 26, 2008
  • 3 Answers
SOURCE: IUniden Max 5 cordless phone with base unit flashes 88
Try a new battery. That is usually what "88" means.
Posted on Apr 20, 2009
SOURCE: Registering handset to base
Reset button on back of rectangular base unit (black and hard to see) - press it down and hold while you choose 'register handset' - should pick it up immediately.
Posted on Aug 07, 2009
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
Why do I see Base no power on display which also shows Charging?
Your phone is trying to connect via radio to a "base station". If you don't have one, your handset cannot work.
If you have a base station, your handset may need to be "registered" to it.
Apr 12, 2016 | Panasonic KX TGA680B DECT Accessory...
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
Wharfedale digital orb twin phone
TO REGISTER A HANDSET
[At the base]
1. Press and hold the the PAGE button on the base station for at least 3 seconds. You have 90 seconds in which to register a handset.
[At the handset]
2. Press MENU and scroll to ADVANCED SET and press MENU
3. Scroll to REGISTRATION and press MENU
4. If necessary scroll to display REGIST.BASE and press MENU
5. BASE 1 2 3 4 is displayed and the registered base number is flashing.
6. Enter the number of the base you wish to register to your handset. If you have only 1 base station, press 1. If you have 2 base stations, press 1 or 2, etc.
7. When the display shows PIN---- , enter the base pin.
8. When the handset is registered to the base it is assigned a handset number.
If you have forgotten your PIN you will need to:
Reset your ORB
1. Press MENU, scroll to ADVANCED SET and press MENU
2. Scroll to RESET UNIT and press MENU
3.CONFIRM? is displayed. Press MENU
[NOTE: Entries stored in the phonebook and new answering messages are retained. You PIN will return to the Default setting 0000]
To Set the PIN
1. Press MENU and scroll to ADVANCED SET and press MENU
2. Scroll to PIN and press MENU
3. Enter the current 4 digit master PIN and press MENU. [Default setting is 0000]
4. Enter the new PIN and press MENU
Hope this has been helpful!
Rob
Dec 28, 2008 | Uniden Cordless Phone
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
Lands Phones Logo
64 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
