Only playing through left feed. No right sound or VU movement at all on the right.
I have removed the housing and had a comprehensive look at all connections etc. and all looks to be in very good order. Any ideas ?
  • 3,904 Answers
Yes, you need to look for burning on the board to give you a clue as to what went wrong but you need to do some voltage checks. Grab a meter and make sure that all the levels are what they need to be at for your unit. Power supply is the number one thing to check.
Posted on Apr 20, 2014
Juki ams 220b dose not go back to origin the same on x scale while you are sewing
Hello Raymond
for that problem , please check X movement sensor( left limitation and right limitation ) if any X sensor damaged machine will not move at correct movement. one more thing , also if X movement not adjusted correctly it will make same problem.
- adjust so that the X right travel limit sensor and X left travel limit sensor respectively actuate when the feed mechanism moves 153 cm to the right and left from the origin by two screws for X sensor base.
thanks and best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Mar 25, 2015 | Juki Sewing Machines
Play back/recording of tapes
check the conections if some where loose.
Aug 25, 2008 | Audio Players & Recorders
Why is line feeding out too fast on 503a
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 29, 2012 | Garden
Toyota corolla 1.6 gli suqeaks when slow cornering
Jack the car up on the left. Once clear of the ground hold the wheel top and bottom at the 12 o'clock and 6 o'clock and check for play by pulling out at the bottom and pushing in at the top and then the other way around. Any movement indicates a loose or worn wheel bearing. To make doubly sure remove the wheel and again check for play in the disc again in the north to south direction. Spin the disc and listen for complaint from the bearing. Hold the disc East/West (3 o'clock, 9 o'clock) and rock back and forward and check for movement against the track rod (steering end) arm. Tighten the central nut on the hub to the point at which resistance to the ability to rotate the disc is felt. Slacken off the nut just a fraction until to regain freedom of disc rotation. Any noises of complaint from the bearing or points of stiffness when the disc is rotating usually indicates that the bearing should be renewed. Now do the same procedure to the right wheel on the other side and make a mental comparison. It is rare for two wheel bearings to go at the same time and so the comparison will serve to highlight a faulty bearing by being markedly different.
Apr 21, 2010 | 2005 Toyota Corolla
My tahoe is vibraiting every time i hit the gas pedal and keep doing it until i took my feed out the gas what do you think
With acceleration vibrations, you should check all your Motor Mounts. Check for rips, tears or worn rubber.
To check the "play" of these mounts:
1. With a partner behind the wheel, vehicle on, in park and them accelerating; and you watching the motor, check to see if the engine is moving (canting) forward, or left or right.
2. Jack-up and properly support the entire vehicle.
Have your partner now place the vehicle in Drive, no brake and accelerate. Check the engine for movement.
3. Have your partner now place the vehicle in Reverse, no brake and accelerate. Check the engine for movement.
Any substantial movement should have the motor mount(s) replaced.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
Mar 02, 2010 | 1998 Chevrolet Tahoe
LG VU Interference?
Some phones are just plain better than others in both reception and transmission. I wouldn't think it is interference since another phone works within the house and on the same network. You might want to look into a home cell phone signal booster (googling that will result in a lot of retailers), but these are by no means cheap. However, they can make a huge difference in quality of service within a structure.
Feb 19, 2010 | LG Vu CU920 Cellular Phone
Technics Tape Deck RS-M227X. VU needles jump to the maximum right
More than likely the pre-amp IC has failed! Trace the wires from the VU meters back they should locate the source of the problem. Remember it will be something common to both channels!
Oct 30, 2009 | Audio Players & Recorders
Printer
What kind of back door do you have on your machine. Does it have a knob that you twist to get it off or does it have pieces on the left and right you have to pinch to get it off. Reason for asking....
There were two versions of this machine put out that had two different service stations and paper feed mechanisms. One version had a motor for the paper feed mechanism and a motor for the service station. The other version just had a motor for the paper feed mechanism and service station movement was tied in to this motor This was done with an altered gear mechanism in the service station. This gear mechanism was cheap and it broke easily. When it breaks you get a knocking/grinding noise and no paper feed or service station movement. It can't be fixed.
THIS PROBLEM IS IN THE MACHINES THAT HAVE THE PINCH OFF BACK DOOR!!!
Hope this helps.
Inkworks
866-381-0541
Oct 13, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Apr 04, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
