Question about LG DLE2532W Electric Dryer
How to replace heating element unit
How to get the old one out
  • LG Master
  • 3,904 Answers
It should be a coil pack right on the back of your unit. You will know it by the replacement part or by the coils of wire in the heating element. Remove the vent hose power and the back of the dryer. about 15 screws hold on the back and about 3 or 4 hold on the heating element. Disconnect the wires and then the element housing. Replace and you are done. Test it before you put the back on it again. The other thing, while you are in there clean out everything you can and cannot see. Trust this from a guy that has had a dryer fire.
Posted on Apr 20, 2014
What is the fix for E63? Have a 2 year old affinity dryer
The E63 error indicates an open circuit for the heating element. The wiring or the heating element may be bad. Check the wiring for any shorted wires (touching the cabinet); replace any damaged wiring. Otherwise, replace the heating element.
You should check that the venting for the unit isn't blocked. Usually the element lasts longer than 2 years. However, the heating system is only covered by the one year warranty.
I hope this helps. Please add a comment with the model number if you want more information on the replacement parts.
Apr 22, 2015 | Dryers
The heat coil stays on for 10-15sec after the fan shuts off. I have replace the thermostat and that did nothing to help. It is a VERY old unit. what can I do other than replace the unit?
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 03, 2011 | Intertherm Heating & Cooling
Electric dryer tumbles but does not dry clothes on any setting. dryer is only 4 yrs old.
Heating element has gone bad. You need to unplug unit. remove back, then find heating element and remove it. Look for what looks like broken springs, if found replace element. 99% of electric dryers not drying are the heating element. Cost around $50
Sep 28, 2010 | Dryers
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
My heating element is DOA on my Keurig B60. The unit is only 15
Nope! I googled the part # found on the element, and It's left me with no results. You need to remove one from a brewer with another issue and transplant it.
Oct 28, 2009 | Keurig B50 Coffee Maker
Replace the upper heating element
hi E mail me model no can proberly sort it. regwoolleu@uwclub.net
Jun 11, 2009 | Ovens
Electric dryer not heating...works fine, but no heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
Need to Replace Heat ELements
you remove the screws that hold on the base plate that has the sequencers mounted on it. pulling it out so the elements clear the sides of the unit. once you remove it you can easily see the heating element coils which you can purchase a restring kit fairly cheap at your local appliance parts store. just remember to stretch it out uniformally the same length as the old one, reinstall the heat kit the same way you removed it. kit comes with new ceramic gromets if some are damaged. these units do have a 5 yr warranty on the heat strips.
Jan 12, 2009 | Ruud UBHC Air Conditioner
Dryer
hi Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
Step 1: Remove the back of the dryer. If necessary, also remove the cabinet top.
Step 2: Disconnect the leads and remove the screws that hold the duct in position. Then lift the entire heater unit out of the dryer.Step 3: Remove the screws that hold the heating element in the duct.
Step 4: Slip the new heating element into the heating duct the same way the old one came out. Be careful not to damage the resistance coils. Replace the screws that hold the heating element in the duct, reconnect the leads, and screw the unit back into position.
now see whether it is ok..............
Sep 12, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
