Question about Coleman 10' X 10' Sundome Tent 9160K101
How to take apart a model 237 lantern. i removed the nut on top but the handle passes through the top into the sides and i cannot get it off. I don't want to break it
  • 3,904 Answers
Tough without pictures but this may be a model that has a spring base the lens is on. Try pushing down. If you post a picture I am sure I can help you out.
Posted on Apr 20, 2014
How do I retrieve the bolt that attaches the main part of the lantern and has fallen inside?
Not sure where it could have fallen into but if you unscrew the top nut you can take off the lens and keep working down taking parts off until you get it all apart. Hope that helps.
Dec 26, 2015 | Coleman Northstar Propane Lantern With...
How to tighten outside door handle on drivers side door
you will have to remove the door trim and tension up the nuts holding the handle onto the door skin on the inside.
Jul 20, 2014 | 2005 Volkswagen New Beetle
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
I do not have the side spray, but there is a dripping that is getting hard to stop. Can't stop the drip and would like to know what I need to do to fix. I have already tightened the screw on the top....
faucet needs new gaskets and springs located below the handle. remove handle, loosen collar nut and remove, pull cartridge out straight up, remove gaskets and springs, take to local Home Depot and buy new and replace. install cartridge, install collar nut, install handle. All finished.
Aug 30, 2011 | Kohler Fort© Single Lever Handle Kitchen...
Faucet is leaking .. i dont know how take it apart .. how do i take it apart???
Turn off the water,remove the little cap on the handle,it is a little hole in the front.use a delta allen key to loose the handle.Remove the retaining nut on top of the valve body.lift up the little (take notice how it is positioned,cause there is a small notch on the side to help you align it propertly)last remove the black rubber washer and the springs,Buy a complete repair kit ,not just the washers and springs.
Apr 13, 2010 | Delta Model 441: Signature Single Handle...
How do you open the housing to change the lamp on a Coleman lantern
you need to unscrew the top nut that holds the steel top piece on and then it will all come apart
Oct 08, 2009 | Coleman Sport & Outdoor - Others
Leakes around spout
You remove the handle after turning the water off the to faucet. Remove the retaining nut which is apart of the trim. The ball assymbly will pull right out and you will find the two little washers and springs below the ball. You can buy a rebuild kit with the new ball if you like but it is not necessary. When you do replace the washers, it might be necessary to tighen the tension ring that is on the retaining nut. Tighten it unit it doesn't leak around the ball stem.
Apr 02, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
How to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
Mar 16, 2009 | Coleman Camping, Backpacking & Hiking
Installing exterior driver side and passaner side door handles
I found this on another page, hope it helps:)
Remove the plastic cover behind the door handle assembly by removing one black 14mm nut from just above the door handle, and 1 screw (usually phillips) from the bottom of the plastic cover.
Remove linkages from lock cylinder and door handle assembly. Use a small flathead screwdriver to slide retaining clips forward, and linkages will come free.
Remove one black 14mm nut from the very top of the door handle assembly.
Remove one phillips screw drom the bottom of the door handle assembly.
Door handle assembly should now come free by pulling out slightly at the top, and pulling upwards.
Transfer lock cylinder and key minder light (if applicable) to new door handle assembly. Lock cylinder is retained by a single TORX bolt.
Reinstall in reverse.
TIP: If you lose or damage any of those black plastic coated nuts, order new ones. They are GM p/n 10067214 and should be around $0.58/each. There are two on each door.
Mar 02, 2009 | 1995 Pontiac Grand Prix
Single handle Delta Kitchen Faucet
The red/blue cover just hides the screw that allows you to remove the handle.
Turn off the water :-)
Remove the handle, you will see that part of the faucet is a large half moon nut. sometimes you can loosen these with your hands, but most times you will need a tool. To avoid damaging the finish with the tool, use smooth jaw tools or protect the nut with a thin piece of rubber/cardboard etc between the jaws of the tool and the nut.
You can then remove the ball/stem, the washers and springs.
Replace the stem, washers and springs and reassemble just as you took it apart.
Be carefull that the little "nipple" lines up with the notches properly.
Take care that you know exactly how it came apart and which direction each prt was facing.
Nov 27, 2008 | Delta Commercial 400-WFELHHDF HDF Series...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
57 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
