Question about GE (PSS26MSRSS) Side by Side Refrigerator
Problem with GE (TFX24RLB) side by side refrigerator. I have ice cubes but no water coming out of front dipenser
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
SOURCE: no water but ice is fine
Hi Leaving the light on worked for me! Awesome solution!! Our water line did not work but the ice cubes still were made. It took our refrig about 24 hours with the light on to work. Thank you for the simple suggestion!
Posted on Feb 21, 2008
SOURCE: GE top freezer ice maker leak
I have the same problem -
Posted on Aug 11, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Ice maker not working. appears no water coming in. water dipenser is working fine in frige.
Pour tap water into the ice tray if empty of cubes. Let freeze and if cubes drop then the dual water control on back of the refrigerator is most likely the problem. Click Here=> Rear of JFC2087HRP you will see part 10 in photo, that is your dual water control valve OEM Part=> 67005154
It can be bad only on ice maker side. Let me know about the ice test so we can determine which part is the problem. If you have more questions please let me know, Thanks Sea Breeze
1ec4065.jpgSea Breeze
Oct 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
PSS23MSTC GE PROFILE WATER WORKS, ICE CRUSHED ICE INDICATOR LIGHT DIMS NO ICE IDEAS?
clean built up ice in the door where ice comes out.....make sure the metal bar is down. its located inside the tray where the stored ice is.
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Automatic ice maker will not dipense ice cubes.
This may be a circuit board problem for which there might be a recall from GE. I had the same problem and found information about it on the web site below.
http://applianceguru.com/view_topic.php?id=13243&forum_id=1
Feb 19, 2009 | GE Profile PSS26NGS Side by Side...
Water dispenser does not work
most likely the water line for the dispenser has frozen in one of 2 places. the first place to check and the easiest is the water tank behind the crisper drawers in the fresh food compartment. what i would do is use a hair dryer to warm the tanke and see if it will start working again. the next place that is common for it to freeze is in the freezer door. the only way to fix this is to leave the door open for a while to allow it to thaw out.
If I'm not mistaken I think there is a recall for some of the  GE sxs refrig that addresses the water line freezing in the door. you may want to all GE and heck on that. good luck peyton
Jan 27, 2009 | GE GSS25LGM Side by Side Refrigerator
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
ICE MAKER and Water Dispenser
very likely a partially clogged filter, but not sure why no light.
Jun 13, 2007 | Amana ARS2661B Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
14 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
