Question about LG DLE2532W Electric Dryer
Change heating element in LG dryer
Need to know how to change the element unit out
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Remove top then remove front and the element is in the lower right corner
Posted on May 12, 2014
  • 40 Answers
SOURCE: heater element-how do you change?
take puttyknife put between top and front panels about two to three inches from sides one at a time push in to release tab top will flip up two screws at top front corners pull front panel toward you unplug door switch and remove front panel then take four screws from roller and duct panel and remove from latches and unplug conector underneath set roller panel aside remove belt from will walk you thrugh the rest
Posted on Feb 23, 2009
hunter19_46m
  • 7482 Answers
SOURCE: LG Dryer won't dry, no heat.
The heating coil is not too big of a problem to replace if you are mechanically inclined and have tools to do the job.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Posted on Oct 17, 2009
  • 45 Answers
SOURCE: lg dryer dle5977w heating element dryer
Yes the heating element is out.
Posted on Apr 28, 2010
SOURCE: need the wire diagram for lg dryer dle2514w
http://136.166.4.200/contents/Laundry/DLG2524/DLG2524_Service_Manual.pdf
Posted on Oct 01, 2010
walesarumi
  • 6993 Answers
SOURCE: LG DLe0442W Dryer working but no heat at all.
Check the heating element. That is were the fault is coming from.
Posted on Jan 09, 2012
How to replace heating element unit
It should be a coil pack right on the back of your unit. You will know it by the replacement part or by the coils of wire in the heating element. Remove the vent hose power and the back of the dryer. about 15 screws hold on the back and about 3 or 4 hold on the heating element. Disconnect the wires and then the element housing. Replace and you are done. Test it before you put the back on it again. The other thing, while you are in there clean out everything you can and cannot see. Trust this from a guy that has had a dryer fire.
Apr 20, 2014 | LG DLE2532W Electric Dryer
Jan 09, 2012 | LG DLE2532W Electric Dryer
Lg 8377 no heat,dryer runs cold.Ran diagnostics,start more dry less dry buttons same time.Saw plc ng.
You may have a high limit switch that has failed. You will need to tear down the dryer to get access to the heating element. Look for the heating element on the bottom right side. There are 2 thermo discs located on the left side of the heating element. Test both of them. If there is no continuity, change that part.
Hope this helps.
Aug 28, 2011 | LG DLE2512W Electric Dryer
I have a lg gromm dryer and it dosn't get hot when drying why?:
I suspect that either the heating element is malfunctioning or the control board is. Sorry but either will mean an engineer's visit ;-0(
Sorry again,
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Gas dryer won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual!
Nov 11, 2010 | LG DLG7188 Gas Dryer
I have an LG DLE2532W dryer. It suddenly stopped putting out heat. I've heard that there's a heat regulator switch that can trip if the unit overheats located underneath the barrel. What's the easiest...
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube, repairclinic.com, appliancepartspros.com
Jun 05, 2017 | LG DLE2532W Electric Dryer
NEED TO REPLACE HEATER ELEMENT
You should be able to take off the back panel and see it. The heating element is USUALLY an easy fix. Let me know if you need any further help.
May 04, 2009 | LG DLE2516 Electric Dryer
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
No heat out of dryer
These units usually have a disk thermostat near the heater coils that snaps open when the unit overheats. Only way to know is to disassemble it usually but you may be lucky and the switch is accessible from the rear. It's a bimetallic switch and available at any repair shop.
Nov 02, 2007 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
74 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
