Question about Ev Rider Powerful Mobility Sport Rider 20k Scooter|Scootercatalog
No power when key is turnd on sportrider 20k
The night before the charger was coming in a out charging
  • david robertson
    david robertson Apr 14, 2016
    check batteries and charger
  • Ev Rider Master
  • 1,263 Answers
Hi ,sorry but that above remark doesn't not make sense, does the scooter turn on ? check you haven't popped any resettable fuse ...
Check the fuses located on the battery leads,,, be careful not to short...lots of current could melt your fingers or start a fire ...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Apr 21, 2014
Wont charge ,tries to come on while plugged in but shuts right back off?
Allow the charger to charge the battery with the tablet OFF over night. The tablet requires MORE power than the charger can provide - but the charger provides enough power to slow charge the battery. In the morning it should be fine - unless the battery no longer can support a charge.
May 18, 2015 | Maylong Android Tablet M-250
I have a JBL Charge and it will not charge. After charging all night with a charger that I am sure is working properly, the blue light will come on then the unit powers off.
If you are positive that the charger is good, then the batteries have died a noble death and need replacement.
They are only good for so many recharge cycles before going to battery heaven.
Apr 05, 2015 | JBL Charge Wireless Portable Speaker for...
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
My psp wont power on
Have you tried using another charger? use another battery? if this does not fix the problem please find a local electronic repair shop or service center near you and let them take a look to determine what is the actual problem..
Jun 09, 2010 | Sony PlayStation Portable (PSP) Console
Screen wont come on
Does it only light up when you adapter is plugged in? If so try taking out the battery and making sure it is in correctly. Press the power button under the screen on the side if the unit and the middle circle in the directional key pad, there should be a menu that comes up.
Jun 17, 2009 | Jazz DV-179 Digital Camera
How do I charge My Pronto M51 motorized wheelchair?
Margie,   Yes you may charge it overnight. If you use it everyday,charge it every night. Once the charger senses 24 volts it stops sending a charge,so they cannot be overcharged.  I suggest when you go to bed put on the charger and unplug it when you get up in the morning.
Mar 28, 2009 | Invacare Supply Group Invacare Pronto M51...
My phone wont turn on.
If the charging light comes on with the charger plugged in you probably have a broken power button. if the charging light does not come on while plugged in, your charging port most likely is damaged. take it to your local cell phone technician. if you havent any nearby you can contact www.fixphonenow.com ,they should be able to repair it.
t
Nov 16, 2008 | Cingular Wireless 8125 Smartphone
87 jeep cherokee tach climbs when ignition is turnd off. and flashers are slow
You say the alt. is dead. Why not replace it? Is the battery light on when you run the car?
If the alt. is bad, you are running all that equipment just on battery power.
Oct 30, 2008 | 1987 Jeep Cherokee
Hi i have a acer 1350 laptop if i charge the battery fully it will work for about 40 mins but when the battery runs down and i plug the mains in the battery carries on discharging although it says power...
Bettter have it checked on the nearest service center if the unit is still under warranty. There might be a problem with your batteries based on our description (very hot).
Jun 19, 2008 | Acer Computers & Internet
Ev Rider Powerful Mobility Sport Rider 20k Scooter|Scootercatalog Logo
85 people viewed this question
Top Ev Rider Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Ev Rider Health and Beauty Expert? Answer questions, earn points and help others
