Question about HP - HP Photosmart 8250 printer
Hp8250 fault code b80c20bc when bluetooth printing any one got a solution to solve this
The solution I can say is to reset the bluetooth settings throug the menu
key menu
select bluetooth
go to the bottom, the last option is to reset settings
here is better than HP site ..............
Posted on Jan 26, 2010
I am new at this service. I emailed in a question yesterday and you asked for more information. I have just recently installed a new hard drive on my computer. In using Quickbooks, I am not able to...
You'll need to go into your printer's preferences when you print from quickbooks by clicking "Properties" in the print dialog. Then search through your paper sizes to find one that is check sized. If you cannot find it, add another paper size that is 6? x 3.75?, which is the size of a check. You might want to cut out a few check-sized pieces of paper to test your settings/margins on, so you're not ruining checks.
Jun 15, 2011 | Computers & Internet
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
I have a hp8250 and about every 6th line is faded
you need to change the printheads but first take a cotton swab dip it in water and then clean the printheads copper contacts and the place the printheads sit inside the printer .place the printheads back inside and now try to print if u still face the issue replace the printheads and then check whether it still gives a problem if it does call in to hp and they will replace the printer.
1800-474-6836
Jun 18, 2009 | HP Photosmart 8250 InkJet Printer
Error messages on HP8250
Hi ok I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2009 | HP Photosmart 8250 InkJet Printer
Hp8250 will not print
No, it should be ok with new cartridges
Apr 26, 2009 | HP Photosmart 8250 InkJet Printer
Wireless Printing set up
In order to print via Bluetooth communication with Macintosh, the following system requirements must be satisfied.
Computer
A Macintosh with an internal Apple Bluetooth module or a Macintosh attached D-LINK DBT-120 USB Bluetooth rev.B
OS
Mac OS X v.10.3.3 or later
In order to connect the Bluetooth unit and print via Bluetooth communication, the following steps are required.
STEP 1
Check that the Bluetooth unit is properly attached to the printer.
STEP 2
Install the MP Drivers.
STEP 3
Check the device name of the printer using the LCD.
STEP 4
Register the printer as a Bluetooth device using Bluetooth Setup Assistant.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have hp8250 photosmart printer it will not print magenta. all cartriges are genuine hp. I have cleaned printer heads numerous times. The problem is magenta only and no error codes show. when I print a...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | HP Photosmart 8250 InkJet Printer
I have purchased two bluetooth devices and have the same problem with both, which makes me think it is my LG enV 9900 phone. The problem is when searching for the device to pair the bluetooth, the phone...
the env has had problems in the past with bluetooths, sometimes a software flash solves the problem
are you making sure that you use 0000 as the pass code?
the best way to test the bluetooth pairing is to see if these headsets will pair with another bluetooth capable phone. if so, then it is indeed the 9900 that is at fault...
good luck
Sep 04, 2008 | Cell Phones
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Bluetooth dongle
Not really, what operating system are you using? on the printer itself set it to bluetooth settings and dont put n a code set but set it to discoverable, then when printing dont do a file print, instead right click on the file and then on your send to option if your computer is detecting the dongle one option will say stylus rx585- then it will print it. one thing that you can check is as belkin manufacturer if their bt dongle is compatible with epson, and FYI bluetooth printng is for photo printng only. doesnt look as good if you are going to print a document or text docs..
hope this helps, and if you have inquiries email me back
if it solved your issue pls rate as fixya, thanks!!!
May 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
223 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
