Question about Freezers
My icemaker in my frezer motor is load
Do not need picture
    Problem Solver:
  • 20 Answers
Remove the ice that is stuck causing pressure on motor
Posted on May 02, 2014
May frigidaire frost free model LFFU1767DW15 have fan motor
Hello David - Typically most of the recent manufacture freezers have fan motors, however some are enclose to where you are unable to reach or see it. Are you having a specific problem with your freezer?
Sep 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire icemaker wont fill with water. Side by side model. The icemaker motor is working but water is not filling in to make the ice.
Take a blow dryer and try to thaw the tube out. It may have froze on you. Please leave good thumbs up for my guess Thanks The Raz Shack
Feb 20, 2010 | Freezers
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
GE side by side freezer/refrig-model # pssz6mcpa-motor in freezer not running, icemaker not working and freezer not cold enough
Sometimes they stick and need a shot of WD 40 and then workit back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 04, 2010 | Freezers
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
GE side by side refrig/freezer Mod. TFH24JWTA WH. Ice maker stopped working, stop/start wire is down (on). Get water through the door, but not sure if it goes to the ice maker. Ice maker is empty of water....
usually yes if no water to icemaker could be water valve solenoid. . first you can remove cover on icemaker and put the unit thru a test mode. find the plastic or medal cam in center of icemaker head when cover is removed., theis is a flateblade screw center get a small screwdriver and turn screw counterclockwise for about a 1/4 of a turn , icemaker will start cycling if icemaker ok then it will go througha cycle let it do its thing usually a few minutes for it to cycle, if fills you may have a bad icemaker, if no fill then valve may be bad. make sure you have good water pressure from your water supply that can cause icemaker problems.
Sep 17, 2009 | Freezers
After clean, the magic chef chest frezer no linger frezen.
I think in the defrosting process, the evaporator was damaged causing refrigerant leakage. sorry... dont try to repair.. it sucks in moisture
Aug 26, 2009 | Freezers
ICE MAKER MOTOR RUNS CONSTANTLY AND WONT' TURN OFF ICE IS FULL
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check pcappliance.com for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Ice maker not making ice
either the thermostat is bad or the heater isnt working. You could take the icemaker out and connect leads to the heater to see if it warms up or use an ohm meter to test the heater and thermostat. Also take the cover off and see if the cog wheel on the motor is broken.
Apr 29, 2009 | Kenmore Freezers
The fridge on my fridge freezer has stopped
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Jan 01, 2009 | Freezers
Freezers Logo
80 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
