Question about HP Photosmart 8450 InkJet Printer
HP 1315 printer won't turn on
My HP1315 printer won't turn on. I plugger and unplugged the pwer cord. The lights go on for a few seconds and then off. The on/resume button when push does nothing. I tried plugging and unplugging the USB cord without any luck. Pleas help.
    Problem Solver:
  • 10 Answers
I have an HP printer too, but it's HP 2050. When i plug it in it usually makes a noise and then the power button blinks. To turn it on requires me to hold the power button down for a few seconds until the power button light stays on. If you haven't tried yet, try pushing down and hold and see if it turns on. Hope this helps :)
Posted on Apr 20, 2014
dodgecharger
  • 254 Answers
SOURCE: What paper jam?
Does the printer even try to pick a piece of paper from the supply tray? If not, then it would appear that a sensor somewhere in the paper path is bad, either mechanically or electronically. Often, these sensors have a lever which touches the paper. If by chance the lever is broken or stuck it won't give a correct message to the logic circuit. If by chance the sensor is electronically defective, it would still give a bad message to the logic, and it would need to be replaced. Logic circuitry could be bad, in which case, replace the printer. With the lowcost printer/all-in-one units these days, it seems fixya has a continual flow of inquiries. Maybe this will give you some help.
Posted on Aug 09, 2007
onlynisar
  • 40 Answers
SOURCE: hp officejet 6110xi all in one
The Non - Volatile memory of the printer needs to be Erased..
1. Turn the printer on.
2. Unplug the power cord on the back of the printer.
3. Press & hold # and 9 key simultaneosly while connecting the power cord on the back of the printer....Donnot release the keys for about 15 seconds after connecting power .
The turn the printer on If it turns off & follow the instruction......
If this will not resolve the printer needs to be serviced.
Posted on Dec 23, 2007
  • 6 Answers
SOURCE: HP Officejet 7410 All-in-one No Power Light
Turn the printer upside down right underneath where the cartridge station is you will find a small white gear...sometime it may be covered with a blue rubber cover.
when you turn the gear ..the barrier in front of the cartridge will go down.
Then do a rest on the printer and then install it.
Posted on Jun 08, 2008
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
  • 27 Answers
SOURCE: hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Posted on Mar 09, 2009
Lost hp 1315 cd --need to install on new computer, but how?
go hp.com/support type in product type hp1315 and download the printer software.
Jan 09, 2010 | HP PSC 1315 All-In-One InkJet Printer
Hp director doesn't work
Go HP website there are a number of reasons the director won't work and they are listed on the site
Aug 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer problems
Not good, ma'am.
Try unplugging the power cord for 10 seconds.
Remove the toner cartridge, look for a jam.
Make sure the paper supply is pushed forward.
Jan 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
WHEN I TURN ON THE PRINTER IT STARTS TO PRINT THE ALIGNMENT PAGE
Hi Mahdavi,
In HP PSC 1315 printer after replacing new Ink Cartridges the printer always prints Alignment test page every time you turn it ON.To resolve this problem you must complete the alignment process.
Steps
1.Turn the printer ON.
2.Once its ON, it will print the Alignment page. Place the page in the scanner bed correctly.
3.Then Press START SCAN button.
4.The power light will start blinking, wait until the power lights turns solid.
5.Now Alignment process is over.Discard the paper from scanner.
6.Turn the printer OFF and then ON, it will not print that page again.
Note:Please follow this steps every time when you replace the Cartridges.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart 8450 InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
