Question about Samsung HT-TZ215R Theater System
My home theatre is turning off after writing fan check, even when the fan is working
The machine turn off after about 2 minutes, and it will display fan chq before it turned off. I check again and fount out that the fan is actually working, but the problem persist.
djnick989
  • 1067 Answers
SOURCE: fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Posted on Jan 09, 2008
SOURCE: my dvd home theatre system ht tx75 keeps shutting down
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Posted on Jan 28, 2009
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Posted on Apr 14, 2009
chipsandnuts
  • 70 Answers
SOURCE: dvd home theatre system
Samsung HTS units have a heat protection mechanism.
Basically the unit shuts itself off to avoid overheating and further damage.
Reasons for this:
Unit's internal cooling fan may need to be replaced
OR
The unit may be sitting on another device (cable box, etc)
OR
The unit may not have adequate space at the back of it.
You can try:
Letting the unit stand alone. No device should be below it. Make sure it has adeuate space on its rear.
If those don't work the unit needs repair.
Hope this helps!
Posted on Jun 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: Fan check shows up on display.
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Posted on Feb 11, 2010
RCA RTD315 Theatre System- When I turn the main unit on, it comes on but shuts itself off after less than a minute????????? Any ideas what's happening? Can I purchase just the receiver anywhere. Have had...
Look like the board over heating. Please check working condition the fan. Keep far the player from wall or items that can possible close blow out of the fan. Also available home theater units avsystemparts.com
Oct 03, 2013 | RCA RTD315 Theater System
Sony Home Theatre System Turning Off
Appears that you have a bad cap in the power supply that is changing value as it heats up. Hard to find - only thing you can do is go to suspected units and replace them hoping that you got the bad one. Or just wait till it finally pops.
Apr 02, 2017 | Sony Home Theater: DAV-DZ870W ALL REGION...
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Region Free Code for HT-Z310T Samsung Home Theatre
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. turn off.
10. Turn player off then on again.
11. Player is now region-free.
My brother did this on his ht-z310 and other than I think maybe the traty not openin g when it said it worked fine and his player is now region free.
I got this btw from:
http://www.videohelp.com/dvdhacks?dv...&Search=Search
Mar 25, 2009 | Samsung HT-Z310T Theater System
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
Rear check message on HT-TXQ120 samsung home theatre
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
Unit wont power up
Respected title!I would ask for their help.there is a yamaha dvr-s 120 home theatre my system.Switching on ,writes it ki,"check sp,and then turns off.what may be the problem?I say thank you for their help!with respect:Hornett
Jan 20, 2008 | Yamaha DVR-S120 DVD Player
Samsung HT-TZ215R Theater System Logo
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
