Question about Cosco Metal Crib
Need 1 end drop slide piece for white metal crib
The crib was given to us as a hand me down and is missing one of the drop end slide pieces. Wondering if I can order it? My baby is done with his bassenett and need to get him in his crib ASAP.
  • 340 Answers
Contact one of the highly trained, very friendly customer service reps at 800-205-9642 or 800-772-1041 and they should be able to assist you with your problem. You can also look at what parts they offer before calling on their user-friendly websites, www.productsamerica.com or www.productsamerica.net.
Posted on Jun 19, 2009
Show assembly for Bassett crib model 5918-505
I have a 5918-505 mI put it togehter for the first time since 1980 I had no problems once I located all of the parts: 4 metal guide rails, 2 wooden ends with 2 wheels in each, 2 wooden drop sides (or front and back that go up and down.) 2 metal toe kick rails that hold the sides up, 1 mattress springs, 4 metal mattress spring supports. attached to the inside of the wooden ends are 4 hanger pieces for the mattress spring support to hang on.
I could supply photos if needed.
Oct 23, 2011 | Bassett Mission Crib
Have a jenny crib white nov 5 2002. no model number available its missing all hardware. I would like to keep crib & assemble.
If you dont have the 2 chrome rods that are 2 feet long, you are out of luck.
They are required. Second, most Evenflos had a recall that requires the model number
to get parts for. The screws are common 10-32 and the back uses 2 extra 5/16 X 2"
bolts with wingnuts. The spring/mattress support slides in thru the metal pieces on the
foot and headboard. The foot kicker that releases the dropside is located on the back-bottom
of the dropside and it stays up with two L-braces that are notched. I really think it's time for a new
crib if you are missing these parts.
call a ParentLink Representative at 1-800-233-5921, Monday - Friday from 8 am to 5 pm.
Mar 04, 2011 | Evenflo Jenny Lind Crib
I lost the instruction Manuel and I need to convert the crib into the toddler bed
First I unbolted the four arms that hold the metal bed support up and pushed it down as flat as I could. I had to do it a couple of times and go kind of slow, to get the loose arms tucked away as best I could. They still stick up a little above the rest of the frame.
After much wrestling with the wooden front panel (gate) of the crib (the one I need to remove), here is what I did:
1. Find the wooden piece that crosses the bed just behind the gate. This is an approximately 1.5-inch by 3/4-inch piece. On ours, it's just above and in front of the drawer under the crib.
2. Find the metal screw at one end of this cross piece. You will see that it is on the outside of the bed, on the short end of the bed, in line with the cross piece.
3. Unscrew it. Note that this screw actually threads into a threaded piece inserted into the cross piece in a little hole on the back side of the cross piece, about 3/4 inch from the end. If this little silver metal piece falls out, you will need to find it and put it back in the hole with the threads facing the screw hole. The piece is the size of a pea.
4. Anyway, use an allen wrench to remove the screw, without losing that little inserted thingy.
5. I'm not saying this is textbook, but I then forced the end of the crib away from the rest of the crib while moving the gate up and down and pulling gently toward me (to pull the gate from its track). You have to move the end of the crib to create about a 1/2-inch gap before the gate will pop free.
6. The gate has two pins on each side, so when you get it freed on the site that you removed the screw on, the other side will come off without removing the second screw on that side.
7. I then got the drawer back on its tracks properly (it jumped the tracks a bit in the process), pushed everything back together the way it was, and screwed the screw back in. (if the screw wont thread, either you lost the aforementioned little silver piece, or that little silver piece is turned in the hold the wrong way)
8. With the gate removed, the crib (now toddler bed I guess) has four little tabs where the gate was once attached. Two I had to unscrew, and the other two I grabbed with a pliers and pulled out.
It wasn't elegant, but I certainly have an intact toddler bed now.
Hope helps. Good luck.
Oct 04, 2010 | Toys
The peace that goes to the side to snug in to the drop is missing...looking for that round piece ....any idea where i can find it
This crib is no longer being sold and Cosco no longer makes cribs at all. Drop-sided cribs are known for falling apart, having missing parts and children end up getting entrapped between the broken drop side and the rest of the crib and dying. Please, do not try and repair this crib, just throw it away. It should not be used for any child. Do not take the risk. It isn't worth it.
Sep 29, 2010 | Cosco Metal Crib
I am missing a piece to a crib that I received second hand. I believe the crib is a Angel Line Jenny Lind Crib according to design matches I've researched. The possible model # is 4-750-1. If possible I...
Hello. Products America may be able to assit you with your parts. You will need to be with your crib and prepared to take measurements when you call in order for them to determine if the parts you need match what they carry. The numbers are 800-205-9642 or 800-772-1041. Hours of operation are Monday thru Friday from 8am to 6pm CST. Have a great day!
Oct 09, 2009 | Angel Line Jenny Lind Crib
Looking for replacement pieces for drop end slide & rail.... did not come with product
The number for cosco repl parts is 1-800-544-1108 from 8am to430pm EST
May 17, 2009 | Cosco Metal Crib
Can not get crib together...need instructions
called the people we got it from and they came and put it together. It would have been impossible without them or instructions
Sep 16, 2008 | Cosco 2 in 1 10-185-WHO Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Replacement part
I am looking for the same parts if you have any luck, please share.
Jul 19, 2008 | Cosco 2-in-1 Sleigh 10121 Crib
Cosco Metal Crib Logo
265 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
