Question about Philips 60PW9363 60" Rear Projection Television
Philips 52 in projection tv blew over in truck
Someone gave me this, said color was a little off. He strapped it down in truck but wind caught it and blew it over. Heartsick, when I got it home I discovered the mirror had smashed. I took it out and put a smaller one in just to see if it would still work. When I was checking it out, I noticed that looking in the blue tube, the fluid looked like it had bubbles in it. Looking in the red and green tubes, I could read "channel unavailable", but not in the blue one. It was just cloudy. After I put the smaller mirror in and turned it on, I was delighted to see it still worked, but when I tried to adjust the convergence of course there was no blue. I checked out the kits at TV RepairKits.com and there are two available. One to replace the chips and one to replace the fluid. Both are $64. Any idea which one it is that I most likely need? I honestly can't afford one, let alone both, so any help would be greatly appreciated.
  • 8 Answers
SOURCE: Philips 50P8341 50 in. Rear Projection Television most of the color is red
Usually if you remove the speaker grill in front there is a convergence panel that can be carefully removed. If you look inside you should see a small rectangular block with six controls. They are labelled focus and screen, and red, blue and green. Adjust only the screen controls very carefully and slowly. I would recommend reducing the red slightly brfore raising the green and then blue until the picture looks acceptable. Be sure to center the on screen controls before starting.
Posted on Dec 31, 2007
Slinteriors
  • 8617 Answers
SOURCE: convergence problem on a Philips projection TV
They should be STK392-120 but check the numbers on yours to be positive. They are located on the extreme left of the chassis looking inside the back panel mounted on a heat sink. They will have STK Numbers stamped on them. Yes you should change both of them they cost 10.00 each at electronix.com You will need heat sink compound as well but this is better purchased at Radio Shack 2.00 per tube. Put a good coat of Heat sink compound on the back side of the new ICs. Also check over the resistors on the board next to the ICs sometimes 1 or 2 of those burn when the Cs go out. Let me know if you need anything further
Posted on Jan 25, 2008
premtech
  • 934 Answers
SOURCE: Philips 51in. Rear projection DPTV345
That is quite an undertaking to replace all three crts in a conventional PTV - I've been in electronics more than 20 years and I've never done that... One because it's far too expensive, two because it's unusual that all three crts would be bad and if they were I'd REALLY suspect problems somewhere else and three because of how labor intensive it would be to remove, install and align three new cans.
That said, you should be able to get them through Vance Baldwin or Tritronics Inc.
Bill
Posted on Mar 13, 2008
Ecollier2012
  • 3459 Answers
SOURCE: bad color
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 22, 2009
SOURCE: installing a convergence kit in a Philips 52" projection tv
http://www.tvrepairkits.com/component/content/article/42-magnavox-kits/90-tv-kit-005.html to purchase a convergence repair kit. $70 shipped.
Posted on May 08, 2009
We have a philips 52" projection tv that my son
If it has a blue cast someone likley turned up the blue brightness inside the TV...there are 6 knobs...2 for each color..try turning that down. Its not the PIP or bad tube...
Jan 06, 2011 | Philips Magnavox 51MP392H Rear Projection...
My 52
YOU NEED TO REPLACE THE CONVERGENCE OUTPUT I.C.
Dec 26, 2009 | RCA P52926 52" Rear Projection Television
Hear a whirling sound within a few seconds of tv image coming up - continues while watching and winds down when the set is turned off (fan?)
It could be the color wheel in the TV that you are hearing. There is a color wheel that spins in order for you TV to display colors and if it is struggling to stay at the right speed, it could cause the sound that you are hearing.
The fans also make some sound as when they spin and will remain on for a few minutes after the TV is turned off in order to cool the TV.
Nov 03, 2009 | Toshiba 52HM95 52" HDTV Projection...
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Philips 29pt5407/21 tv doesnt start up and its beeping
Sometimes you can reset a TV by pulling the power cord our for about 2 minutes and then try to turn it on.
Aug 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Phillips cineos 52 inch have sound but no picture
i have a 52 projection tv phillip and the pic is off you see three images on the bottom nice pic in the middle and on top a little off.so what is the problem
Jul 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Green color has taken over tv
OK IF THE COLOR GREEN HAS "TAKEN OVER YOUR TV" AND YOU USE A CABLE BOX, ITS PROBABLY THE CABLE BOX. I HAD THE SAME PROBLEM. YOU JUST NEED TO EITHER HIRE SOMEONE TO COME TAKE A LOOK AT THE TV AND/OR CABLE BOX, OR BUY A NEW CABLE BOX AND/OR TV! SIMPLE,HUH?
May 31, 2009 | Philips 50P8341 50" Rear Projection...
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture is to light
Hello nita-1991,
Go to the Philips site http://www.philips.com and get the users manual. them get the remote for your TV from:
http://www.magnavoxremotes.com/
I hope this helps
Shuttle83
Jul 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips big screen tv
Does the power light light up when power is pressed? Does it blink? If so how many times does it blink? Have you checked the fuse?
May 19, 2008 | Philips 60P8341 60" Rear Projection...
Philips 60PW9363 60" Rear Projection Television Logo
14 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
