Question about Scotsman Refrigerators
Scotsman ice machine continuous water flow
Cmd506as
    Novelist:
  • 187 Answers
If you have a continuous flow during operation you need to replace the supply water solenoid valve. These valve are available at most cc dickson supply houses or through your local refrigeration tech. They will need you model number.
Posted on Sep 30, 2014
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
Posted on May 04, 2008
TheMobilian
  • 8220 Answers
SOURCE: i am looking for schematics or online manual scotsman ice machine
page 13
Posted on Mar 01, 2009
  • 219 Answers
SOURCE: Problem with ice/water dispenser on Frigidaire FRS26ZRG
change the microswitch
Posted on Mar 19, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a scotsman commercial ice machine mdl#
I am going to assume that the machine has been cleaned, I would adjust the cube thickness to less.
Posted on May 06, 2010
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
The water only flows then it stops
Check water filter or make sure water is on....sounds like slow water fill
Jul 31, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My scotsman cm universal service controller keeps shutting off and refrigeration light blinks twice. But there is plenty of freon. What is the problem?
Most likely water inlet valve. When they get stuck open water continuously flows in preventing it from from freezing and therefore the controller thinks it's running and not getting cold enough so it cuts off on refrigeration. It will cut off on water if no water is detected.
Nov 06, 2012 | Scotsman Ice Maker 600LB CM3 30inW...
Can`t get scotsman cme250 to work properly. either doesn`t make ice or won`t harvest ice. when cube size thermostat is turned up so it makes ice it takes long time to start forming cubes. electrical...
The problem could be a series of things beginning with ambient temperatures too high, fan not working properly, if water cooled there could be a problem with that also. As a technician I would first look over the condenser and make sure air flow is proper and then attach my gauges to see the suction and discharge pressures. I have found many restaurants that keep their ice machines in the hot kitchen where it creates high ambient temperatures and allows grease from the grill to collect on the condenser blocking air flow. Yes under charged is possible or over charged but the best and most effective route is to call a Scotsman Certified Technician. I have worked on Scotsman's and they are very tricky to fix unless you know the process of event. If water is not pre-filtered there is a chance that the water control valve may be stuck open allowing warm water to continue flowing causing these symptoms. Here Is a=> Scotsman CME250 Ice Machine User Manual If unable to find these simple checks above or from the manual and still having problems it will need to be time to call a Technician. If you do not have Adobe Reader Click Here=> Adobe Reader X (10.1.0) Tell me what you find and please don't rate me if I was unable to solve this from here. I am here to help you up and to the point of calling Scotsman for addition help. Thanks, Sea Breeze
Jul 15, 2011 | Scotsman Ice Machine, Cuber, 1825 lb....
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
Oct 21, 2009 | Scotsman DCE33PA1BC 15in Built-in...
A continuous grinding sound on my Scotsman DCE33A
I would suspect the water pump is making this noise. If it is, there is no repair, you must replace it.
Jul 01, 2009 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Refrigerators Logo
109 people viewed this question
Top Scotsman Refrigerators Experts
john h
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
