Question about RCA RS2030 System
DVD CABLE TO SUBWOFFER AND REMOTE
I AM LOOKING FOR THE CABLE FROM THE DVD PLAYER TO THE SUBWOFFER AND REMOTE,IF ANYONE HAS IT CONTACT ME AT APPLEBARTER@AOL.COM,I HAVE CHECKED EBAY AND ALL OVER JUST CAN'T FIND IT.
Remote with no code search button. TDE system # SKU#33201048 looking for the code for sanyo flat screen tv and direct tv cable box and Samsung blue ray player
If your Samsung remote does not offer some sort of code search capability you may only able to control your Samsung DVD player by pressing the DVD button to turn it on. It may be more practical to purchase an inexpensive universal remote and use it to control both your TV and your DVD player.
Dec 26, 2015 | Samsung Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
I am looking for a couple of components for my Curtis Protable DVD Player. First i Need to know what battery goes in the remote and second is the A/V output cable.
Most remote controls take AAA batteries, if you open the battery door, it should say "AAA" or "AA" there, which indicates the battery type.
As for the A/V cable, typically for a DVD player you will want a composite RCA video cable, which will be a cable with three connectors on each end, usually red, white, and yellow. Just match the connectors to the equivalent colours on the DVD player and the back of the TV.
May 02, 2011 | Curtis DVD7026 7 in. Portable DVD Player
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Looking for actual remote control(not code)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370033038767&ssPageName=MERCOSI_VI_ROSI_PR4_PCN_BIX&refitem=220212413655&itemcount=4&refwidgetloc=closed_view_item&refwidgettype=osi_widget&_trksid=p284.m185&_trkparms=algo%3DSI%26its%3DI%252BIA%26itu%3DIA%252BUCI%26otn%3D4%26ps%3D42
Jan 29, 2008 | Cyberhome CH-DVD 300 DVD Player
Lg remote control codes
i have a lg monitor /tv model number M197WDL with no remote control ,so i am looking for the code to put into my one for all
Jan 08, 2008 | Televison & Video
Need Emerson Remote for color TV with DVD Player
You need the remote codes for your cable remote? (if so who is your provider?)
or you need to buy a remote control for the tv?
Nov 19, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
VM9510 Remote
Ebay i just found a sed one
Oct 13, 2007 | Jensen VM9510 Car DVD Player
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
RCA RS2030 System Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
