Question about Sirius Xm Satellite Power Cord Charger Plug
If i have the power cord and plug it in a car what would happen
VIZIO power failed, PC blacked out and will not start. Power cord LED goes off immediately when plugging into PC.
whatever happened you need to fix the TV first and maybe not try to hook the laptop back?
Nov 05, 2012 | Televison & Video
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
My son plugged the wrong power cord into Sony Playstation. now when he plugs the right cord in nothing happens. Is there a fuse or something that can be replaced?
is it the power cord i assume ? make sure the little flip power switch above the power cord is in on position. and u should have steady red light on front of ps3 when unit has power on. using a different power cord should not affect it but its not recommended . most ps3 uses a standard power cable.
Mar 06, 2010 | Nintendo Wii Console
I plug it into the car and it will not keep the charge, it shuts off
This happened to me, take your garmin inside and connect it to your computer let it sit for about 10 mins,then disconnect it make sure the power is on After the splash screen, when it says loading map data, plug it back in quickly, this will bring it into charge mode. Now leave it connected for a couple of hours, then return it to your car. this happened to me becuase I do not have the proper power cord. I'm using a USB car charger, therefore I have to unplug and plug in every time I turn on the car. I need the cord that connects to the dock.
Mar 06, 2010 | Garmin nuvi 260W Car GPS Receiver
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
Won't Power up. Plug in power cord and when you
i can't to the internet with the wire only wireless what is the problems
Oct 14, 2009 | Toshiba Satellite 2455-S305 Notebook
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Battery indicator flashes even when plugged in to electrical plug, computer recognizes plug-in. Computer will not run with power cord.
The battery indicator flashing when plugged in to electrical plug means your battery is completely dead and won't charge. You're computer should run with just the power cord. Your power cord most likely needs replacement.
If you know anyone with the same model of laptop ask if you can borrow their power cord and/or battery to test it out. It is rare for the problem to be the motherboard, though it does happen.
It may just be the power cord at fault as the computer should run without the battery, so you should replace the power cord, as it is probably the reason the battery is completely dead.
If the battery is at least a year old I would replace it since they generally don't last too much longer than a year.
Sep 09, 2008 | IBM ThinkPad T40 2373 Notebook
Sirius Xm Satellite Power Cord Charger Plug Logo
Top Sirius Car Audio & Video Experts
xxxxxx xxx
Are you a Sirius Car Audio and Video Expert? Answer questions, earn points and help others
