Question about Sony Ericsson T310 Cellular Phone
Mobile phone T.310 Sony Ericsson
Hi ! can you help me ? with my mobile have big problems ...when i switch on my mobile switch off after few seconds repeats switch on and switch off ,
what is the problems?
SOURCE: Problems with My Sony Ericsson W580i
usb not connect to pc and valume vere vere slow
Posted on Jul 26, 2008
SOURCE: phone dead after opening java executor
if you run executor, which is put on phone during patch unlock process, then this will tempory kill phone, the cure is to Flash the same main firmware back to the mobile
Posted on Aug 22, 2008
hi my nokia 5300 is not starting up
Posted on Sep 22, 2008
I had the same problem with a k800i, i emailed sony ericsson and they told me what to try and it worked however you do lose everything you had stored on your phone. I believe this will work with most if not all sony ericsson phones. You need to update your phone, here's what to do;
1.Go to
2.Select UK
3.Select your model of handset
4.Click on Sony Ericsson Update Service
5.Click the link, and then click Run or Save.
6.Let the Sony Ericsson Update Service install.
Once you have installed the Sony Ericsson Update Service you will need to launch it. Once it opens simply follow the instructions that you will see on screen. The update should then begin.
Posted on Oct 22, 2008
  • 53 Answers
SOURCE: Sony Ericsson W850i phone has white screen
on Sony Ericsson phones white screen phone is mostly related to software problem. Filesystem is corrupted and it shows white screen. You just need to upload fresh firmware. You can flash fresh firmware using WotanClient2 at
Posted on Feb 11, 2010
SOURCE: Sony Ericsson K800i - Power Switch on Problem
on/off swich path
Posted on Mar 08, 2010
0 characters
1 Points
Says emergency calls only
It means you're not allowed to use the network where you are. Here's the manual. You should contact your provider to fix your issue.
Jan 04, 2014 | Sony Ericsson W760i Cellular Phone
How accsess the internet of w205 walkman....
As your using sony ericsson walkman it can access internet your mobile is just fine it does not any problem you need to follow few steps so that you can access to internet through your mobile.You need to call your customer care after a few minutes they will recive your call tell your number to the customer care people.After that tell them i want to use internet from my mobile and i am using sony ericsson w205 mobile.They will tell you to send a message from your mobile to some number that will be free of cost.Send that message to that number after a few minutes you will recive settings for your mobile save that settings.Switch off your phone for one minute after that switch on your mobile and then go to menu select internet option after this you can start using internet from your mobile. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 14, 2011 | Sony Ericsson Walkman W205 Cell Phone
Turning on this sony ericsson 5801 walkman!
there will be a small button on the top of the mobile else the call cut button must be pressed for few seconds to switch it on or off
Jul 01, 2009 | Sony Ericsson Walkman W810i Cellular Phone
How i put sony ericsson in mobile mode
switch off ur fone, then switch it on, u get 2 modes FLIGHT MODE & NORMAL MODE.
switch to normal mode.
now ur fone will be in mobile mode.
i hope ur problem has been rectified.
all the best
Mar 09, 2009 | Sony Ericsson T250i Cellular Phone
Sony Erricson z550i Phone display not switching on!!!
in most cases the fibre ribbon gets worn out.
you can try a local cellphone repair shop, or sony service if you can afford it.
the ribbon needs to be replaced.
Jan 15, 2009 | Sony Ericsson Z550i Cellular Phone
W200I software problem
Are all songs of the same format and bitrate?
Jun 09, 2008 | Sony Ericsson W200i Cellular Phone
Problem with Sony Ericsson k800
take the phone to a mobile service center and have them repaced your speaker this will correct the issue that you are having with your phone.
May 29, 2008 | Sony Ericsson K800i Cellular Phone
How to unlock sony ericsson 310
What is the exact mobile model? Anyway, you can get the unlock code for your Sony Ericsson 310 mobile either from your service provider or from online site. Try , they provide codes at affordable price, with simple unlocking instructions.
May 02, 2008 | Cell Phones
Sony Ericsson T310 Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
