Question about SE Electronics SE2200A Professional Microphone
SE2200A - Rewiring?
Hi everyone! I dropped my SE2200A and the two cables (red and black) on the top came loose from the cuircuit board. I want to solder them back but I don't know where to solder them (to which part of the circuit board). Can anyone help? Thank you! Filippo
  • Filippo DallAsta
    Filippo DallAsta Apr 22, 2014
    Or I would really appreciate if someone could post a picture of the inside of their SE 2200A, so I can see which cable goes where.
2 Suggested Answers
  • 12 Answers
SOURCE: frequency settings on se2200a
It is a pad..which is a switch that will 'reduce' sound level or volume which in a nutshell is useful for recording loud instruments..So switch to -10 db if placing the mic fairly close to say loud drum or horns..etc..
Posted on Mar 20, 2010
I HAVE A RV WITH AN ELECTRIC FIREPLACE, ITS A HEF26 FROM CFM CORP, DOES ANYONE KNOW WHERE THE RESET BUTTON IS? IT JUST STOPPED WORKING, NO BLOWN BREAKERS
Hi I HAD THE SAME PROBLEM. I TOOK THE electronic BOARD OUT AND FOUND that the main power relay (that's the big black square on the board with the black and red wire connected to the top of it.) solder joints were loose. I bought a cheap soldering gun and resoldered the relay connections at the bottom of the board............Works Fine now................FC
Jan 12, 2013 | Heating & Cooling
I NEED TO KNOW IF IT MATTERS WHAT WIRES ARE CONNECTED TO A 40 30 AMP CUIRCUIT BREAKER
What kind of cuircuit breaker is it 40 or 30 amp breaker it makes a big diference for 30 amp breaker you need # 10 wire
for a 40 amp you need # 8 wire
hope this will help.
Karl
Dec 17, 2011 | Electrical Supplies
Garmin 550t. When i have my zumo on my motorcycle mount it seems not to take power from the bike & then after a while it tells me "low battery", it is wired directly to the bike battery so it should...
Moisture has probably gotten inside the motorcylce cradle through the connector pins. if you take it apart, there is a very small ribbon cable that attaches from the pins to the cicuit board. if moisture gets on the end of the ribbon cable it can short out the small power tracers on the cable and cuircuit board. this happened to me. i had to buy a new cradle. 85.00
May 16, 2010 | Garmin zumo 550 GPS Receiver
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Polaroid TLX-04240B going to a black screen after running for 2mins. Any ideas on how to fix this?
open the black plastic panel and the aluminum panel which has 3 screws each in the back of the tv.
look at bottom left corner of top board. to the right of the red led light,
there's these four white small switches. turn the bottom two switches to "on" and tv should be working.
It's very simple to fix the problem to everyone.
My tv capacitor was not the problem.
I hope this will help everybody.
Jan 04, 2010 | Televison & Video
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
Belkin 1500va (uses 2 - 12v 7ah batteries)
check out this picture, it shows the 2 batteries wired up.
Notice that the batteries are flipped opposite of each other.
So from left to right its: bottom red, bottom black, top black, top red
http://www.pcstats.com/articleview.cfm?articleid=1092&page=2
Between the 2 batteries there is 1 red to black connection.
Then black to black-wire to circuit board
and red to red-wire to circuit board.
Aug 22, 2009 | Belkin (F6C800-UNV-PL) UPS System
Frequency settings on se2200a
May 30, 2009 | SE Electronics SE2200A Professional...
SE2200a, No input signal
If my comment helped you find this problem, could you respond to the fixya questionnaire accordingly?
thanks...
Charlie
Apr 20, 2009 | SE Electronics SE2200A Professional...
Color problem
hi it could be a loose cable in the back of the tv
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
SE Electronics SE2200A Professional Microphone Logo
Top SE Electronics Audio Players & Recorders Experts
Michial Gueffroy
Willem.
Willem.
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
