Samsung WF338AAB/XAA Front Load Washer 3E Error
I just got a 3E error on my washer which according to the manual means high voltage. The cycle stops midway. If I do a normal deepsteam mode, it stops after going through the washing phase, before rinsing phase.
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
Posted on Jul 09, 2008
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
RixsFixes
  • 2200 Answers
SOURCE: my kenmore front load washer keeps showing a F--20
Hi
The F20 error on this machine indicates that there is no or very little water coming into the machine. This means that the pressure switch is not being activated after a while and the error is then thrown up.
See this excellent FixYa link for a complete breakdown of the problem and how to troubleshoot and then solve it.
Acknowledgement jsrock516 for this excellent breakdown of the problem
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
Please do rate my answer. Many Thanks.
Posted on Aug 27, 2009
  • 296 Answers
SOURCE: cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Posted on Sep 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore front load washer error code E 10
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung vrt front load washer
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
Aug 16, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
My machine leader stoped it give me a number 3E WHAT THAT MEAN
This video will help you diagnose the fault on your samsung 3e error codes and the video will help you solve the problem
Mar 08, 2013 | Washing Machines
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
Errhr code ee
There is no error code ee
Could it be 3E or E3
if is 3E then it means "High current detected"
if its E3 then it means "Motor not running properly"
here is the link to the manual I checked all manuals starting with the model number Wf337AA the error codes are all the same.
http://downloadcenter.samsung.com/content/UM/200710/20071010083409359_WF337A-02440A-06[1].pdf
Jul 11, 2012 | Samsung WF337AA Front Load Washer
Error code 3E says Power 81W OFF so what is this? What do I do?
Error code 3E means high currrent detected. Is anything blocking the drum or motor from turning.
Jan 17, 2011 | Samsung WF328AAW Front Load Washer
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Samsung error code 3E?
Aug 12, 2010 | Samsung WF328AAW Front Load Washer
Cycle stops 3E code appears
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
