Question about KLH HD53B Main / Stereo Speaker
How to set up a HD-53B - KLH HD53B Main / Stereo Speaker
  • 4 Answers
Should just need 1 speaker wire per speaker and plug it into your amp!
Posted on Apr 24, 2014
SOURCE:
Tip
HD to YouTube - Upload HD video to YouTube with the best quality
YouTube’s HD service has been on for quite a while now and it is great for users who want to share their HD videos without sacrificing the quality. But HD videos taken by different video camcorders are in different formats and different qualities. To upload HD to YouTube in the best quality, what are recommended by YouTube are videos of the following settings:
MPEG4 (DivX, Xvid, H.264) format
1280×720 resolution
128k Mono or 320k Stereo MP3/AAC audio
24,25 or 30 frames per second
Up to 1GB file size and 10 min. duration
Many HD videos may come in AVCHD (mts or m2ts), TS, TP, TRP, MOD, TOD, MKV formats, and they cannot be directly uploaded to YouTube HD. Therefore, to upload such HD videos to YouTube with the best quality, you will need to convert them to MPEG4 format that meets the above criteria. If you are running Mac OS, Doremisoft Mac HD Converter will be the perfect choice, because it allows you to convert AVCHD to YouTube HD, MOD to YouTube HD etc. with the above best settings.
To convert HD to YouTube, you can simply follow the steps below:
Step 1: Import HD video to Mac HD Video Converter
Click the "Add File" button to add the HD videos you want to upload to YouTube
Step 2: Select MPEG4 format and set the best settings for uploading HD to YouTube
Click to open the "Profile" drop-up list, move your mouse pointer to "HD Video", and you will see all the preset HD formats from the right menu. Click on the "HD MPEG-4 Movie" to select it.
Then click on the "Settings" button to the right of the right of the Profile drop-up list to open the settings window. Then, set the settings according to the above recommended settings by YouTube. See the figure below:
Tip 1: Tick the "Apply to all" button to apply the current format and settings to all the added HD files.
Step3: Convert HD to YouTube
Click on the Start button on the lower right corner of the main interface to start converting your HD videos to YouTube with the best quality for YouTube HD.
Now, you have your HD videos with the best quality forYouTube HD, you can just log in your YouTube account and upload the converted HD videos to YouTube.
Click here to see detailed info of Doremisoft HD Video Converter for Mac.
on Jun 21, 2010 | Computers & Internet
Reset oil change light on Yamaha hw125
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
www MajestyUSA com
YZFR 125 OIL SERVICE LIGHT RESET OIL WARNING LIGHT RESET OIL WARNING
Yamaha Owners Service Manual Xenter HW125 53B F8199 E0 CP67 eBay
OEM parts for Yamaha
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 28, 2014 | Yamaha Motorcycles
Build p050 tank
can you give me all assembly insractoin of this tank?
Sep 01, 2013 | Cars & Trucks
If we have an hd-ready television and we have dishnetwork hd does their box make our tv hd? Or do we have to have their magical piece of equipment to make our television hd?or tv is the WS-55315 model.
You need a HD box connected to the DTV input on the back of the set (it is marked 1080) This set has only one HD input for this---HD ready means it will work only with a box (some newer sets have a HD tuner built into them and for basic HD channels do not need a box).
SD TECH
Jul 11, 2010 | Mitsubishi WS-55315 55" Rear Projection...
It is digital (HD), I don't need converter?
If your set is labeled as "HD ready" then it will accept HD signals from, for example, an external HD tuner or other source. The set can be HD Ready, as is my Samsung TV, but my set has only the older NTSC type tuner. I therefore use a digital stream HD tuner which works great to receive over the air signals. Also digital does not mean a set is HD. There are sets that are standard definition digital sets that can receive digital signals, but do not produce HD. If you are using cable, in most cases, you can continue receiving your cable as usual.
Nov 25, 2009 | Toshiba 36A40 36" TV
How do I set up for HD?
This model should only have one HD input--with a cable box or sat box you connect into the COMPONENT INPUT ON THE BACK OF IT.
This is what I call a first generation HD set--picture will on HD be letter boxed picture. The later sets had this and the full screen 16X9 formats.
This set does not have a HD tuner built into it, the only way to get HD is through the component input.
If this helps you rate this solution as I do this here for FREE.
SD TECH
Nov 19, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Poor picture quality
First of all do you have a HD signal?
these sets are made for HD and most look good when you set the HD box to 1080i , the cheaper sets do not look good with a non HD signal.
check all inputs, dvd, HD air, and component and post which are bad to get more help
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 26, 2009 | Televison & Video
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
KLH HD53B Main / Stereo Speaker Logo
66 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
