Question about Amana NAV2335A Top Load Washer
Clean amana washer lint trap
Where is the Amana washer lint trap?
  • 1028 Answers
SOURCE: How to change drive belt on Amana washer
remove the 4 bolts holding motor to tub and frame remove wire harness from motor remove pump hoses turn assembly upside down 3 torx screws hold pump to motor note routing of old belt around idler pulley and pump studs reinstall in reverse
Posted on Apr 24, 2008
SOURCE: Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Posted on Mar 01, 2009
  • 3600 Answers
SOURCE: Amana ALG8665Ac Gas I have cleaned all lint out
you need a new heater element. or your vent pipe is plugged, try the vent first and if it's clear then the dryer heating element is bad.
Posted on Jun 19, 2009
  • 88 Answers
SOURCE: how to clean internal lint buildup
Buy a lint brush at Walmart or other retail store. It's a long plastic bristle brush that will allow you to reach down in to the cavity of the blower intake. I always use a vacuum hose to **** up what it pulls up so it won't fall back down in.
Posted on Nov 18, 2009
Testimonial: "Thanks much. will give it a go. "
  • 84 Answers
SOURCE: Amana washer won't agitate when full with laundry
The belt is probably worn down. Replace it.
Posted on Jan 17, 2010
I have an Amana Dryer, ned7200tw. It was taking forever to dry clothes, took twice through per load. We replaced the heating element 2 days ago, cleaned all the lint while it was apart, and it is still...
Did you check the trap door on the outside of the house where the vent goes outside. If the door is stuck or the end of the vent is blocked you will get excessive dry time like you are having. Also possibly a thermostat inside starting to go bad and sticking.
Mar 01, 2015 | Amana Dryers
Dropped something down the lint trap
If it's a metal utensil that responds to magnetism, try a magnet on a string, or one of those telescoping magnetic picker-upper tools to get it out.
Jan 22, 2014 | Amana NDE2330AY Electric Dryer
Does a Amana commercial quality washer (model LWA50AW) have a lint trap?
You will need to remove the agitator and inner basket to access and replace the lint filter. It is best to replace the filter and not to try and clean it.
Here is a link to the filter.
Oct 13, 2012 | Amana NAV6800AW Top Load Washer
Amana gas dryer LG8319W/L2
try getting a lint trap brush its long so u can get all the way down in the trap try cleaning that first that is usally the problem
Nov 17, 2011 | Amana Dryers
Iget alot of lint in my laundry cant find lint
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open). All dryers have a lint trap (building codes probably even require it).
May 15, 2010 | Amana NAV2335A Top Load Washer
Mar 26, 2010 | Amana NAV2335A Top Load Washer
What start
check thermal fuse it is located n the back or on the inside behind the lint screen its usually white plastic and is round or oblong you can check it by jumping it out .if that is the problen you need to clean out the lint trap and hose dont forget to clean the port outside the house,after the fuse is replaced otherwise it will overheat and pop the new fuse
Mar 20, 2010 | Amana DLE330RAW Electric Dryer
My amana gas dryer is not heating
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Sep 04, 2009 | Amana NDG5800 Gas Dryer
Grease marks left on clothes in the washer.
after parts replaced
you can still by a new drum and outer shell for that machine
main shell of washer
main shell plastic or metal
http://www.appliancepartspros.com/parts-for-amana-nav3335aww.html
grease may be trapped between inner drum and
if taking apart steam/pressure clean between the drum and internal
use full container of borax
use very hot water
and run an empty full load wash
95e11510-432b-415a-a332-4ca6f8fe25b9.jpg0028599314_6-cqwqmhrjackcqvld1tze14pd-2-2.gif
Apr 27, 2017 | Amana NAV3335A Top Load Washer
Amana NAV2335A Top Load Washer Logo
189 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
