Risk of screen burn-in?
I have some Philips (widescreen) crt tv, and i forget sometimes to set timer on the tv when i go to sleep, and when my digital receiver goes off, my screen goes blue, and stays blue sometimes for 3-5 hours, depends when i wake up, i was wondering if there is any risk of screen burn in when it's blue?
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
There is no screen burn occur to with an all blue screen.
Posted on Apr 21, 2014
Testimonial: "Ok, thanks!"
  • 1 more comment
  • Freyr Sigursson
    Freyr Sigursson Apr 22, 2014
    One more question, so the blue screen won't harm my tv in any way if it stays for hours?
  • Whip Lashaway Apr 29, 2014
    It won't cause a burn in but, it's not good for it. you might see the day that the blues start to fade and you would have to do a setup to get correct colors back. basically your just wearing out your blue circuits and phosphor dots quicker than the red and green.
  • Freyr Sigursson
    Freyr Sigursson May 25, 2014
    Ok thanks alot!
  • 1694 Answers
SOURCE: RCA 32V432T
FIRST THING TO TRY IS RESET-unplug AC cord for a few minutes,hours or overnight==let me know if you need more help.T.
Posted on Oct 09, 2007
SOURCE: New tv won't set up channels
We are returning the tv to RCA and getting our money back.
Posted on Apr 18, 2008
welcomejee
  • 10594 Answers
SOURCE: sleep timer?
Sleep Timer option is available in remote only.
Posted on Aug 10, 2008
bkvinr
  • 76 Answers
SOURCE: philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
Posted on Aug 15, 2008
bunnydawg
  • 5158 Answers
SOURCE: JVC N Series TV "stuck' in sleep/timer mode, won't wake up
try pressing the timer button again and then if that does not work go into the menu and look for power saving options. shut off the timer by that way. make sure the tv is on the video setting and not av or dvd if it has those as you won't see the menu.
Robert
Posted on Sep 26, 2008
Burning smell from tv
UNPLUG SET ASAP AND DO NOT TRY TO TURN IT ON OR POWER IT UNTIL IT IS OPENED AND EXAMINED BY A QUALIFIED PERSON, no TV is worth the risk of a fire and if smoke that risk exists.
Dec 11, 2012 | Philips Magnovox Telivision Set With Vhs...
Philips 60PW9363 60-Inch Widescreen HDTV-Ready Projection TV discolored. possible crt fluid issue??
Thats sounds like the classic sign of CRT coolant needing to be replaced you can get the phillips CRT coolant kit from www.tvrepairworld.com and it comes with the coolant for all 3 CRTs and the instructions
Nov 08, 2012 | HP Philips 60Pw9363 60-Inch Widescreen...
Analog white-westinghouse tv has blue screen and no sound. Connected to digital converter. screen does not change and after 5 minutes the tv shuts off
the glitches could have fried part of the tvs main chip
i have had it happen to me a few times and or it was a fuse
Aug 06, 2012 | Televison & Video
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
Tv philips 29'' 29PT 9416/12 the time that the tv is on automaticaly alone stop. Then i turn on tv and it works.
You may have "sleep timer" set up. Try selecting "Timer" on your remote control to see if the "sleep timer" set. if so make it "0".
Nov 24, 2009 | Philips Televison & Video
MY PHILIPS WIDESCREEN KEEPS TURNING ITS SELF OFF
CHEEK UR POWER SETTING AND SLEEP TIMER YOU WILL FIND THE SETTINGS IN UR MANUEL......MAKE SURE SLEEP TIMER IS SET TO OFF
Nov 19, 2009 | Philips 42PF5521D 42 in. HD-Ready Plasma...
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
The sleep timer do not work
call the custermer service the number is on the manula...tell them if they could help..
Mar 08, 2009 | Philips Magnavox 27MS343S 27" TV
Now using an hdmi to dvi cable - screen size has reduced
Your digital box should have aspect settings as well. When watching HD TV and or movies there is a possibility to get the black bars on top and bottom. It all depends on the ratio it was filmed in.
Nov 18, 2008 | Philips Televison & Video
Remote controler
press picture/sleep button. use the buttons on lower left to set. press arrow bouttons to set time and hit enter (middle button)
Jul 05, 2008 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
