Question about Samsung Cell Phones
Gt 1905 stuck in reboot recovery
My Galaxy is stuck on Samsung logo. Why won't it switch on?
Samsung Galaxy Android Smartphone: Stuck on Samsung Logo (booting up)
Hello.. I'm assuming that you did not try to install a ROM or update the firmware in any way.. doing so and interrupting the process or if on a bad connection with WiFi, or downloading a corrupt install file can break your phone causing problems.
For whatever reason this happened try the following instructions:
  • pull your battery out
  • then re-insert after 30 seconds
  • boot into recovery mode (see attached video) [Press at same time: Power button, Volume up, and Home button.. when you see the blue words at top take finger off Power while still holding other buttons down until you get into Recovery Mode (you will see a bunch of lines of text.. if you see a little green robot says "installing system update" let it do it while taking fingers off all buttons.. it may say "error" = ignore this.. then you will see all the text]
  • wipe date, wipe cache, reboot [*be extra careful what you select: use your down volume key to scroll to wipe cache partition" use the power button to select this [you do not want to select "wipe data/factory reset" unless there is no other hope of getting back into your phone]
  • it takes less than a second to wipe the cache partition, then use the power key to select "reboot system now"
If the phone reboots fine you are done..
>> If the phone refuses to reboot, and hangs again at the Samsung Logo, then you know you have to go back into Recovery Mode and select "wipe data/factory reset" = after which you should be able to get back into your phone but it will wipe all of your data/everything clean from your phone. Your phone will be as if you just bought the phone with nothing of yours on it. You will have to setup your phone all over again.
Jan 30, 2016 | Samsung Cell Phones
How can I put my Compaq Presario F756NR back to the factory configuration?
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select the first date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jun 03, 2011 | HP Compaq Presario F756NR Notebook
1781 - disk failure problem startup for HP nc 6220
This happens if the harddisk data is corrupted.
Hard disk has a data that the computer reads first before going to the operating system. To fix this to to do a debug or do a full format of the hard drive. Try to run a diagnostics first by pressing the F9 upon the HP logo. if it does not report any error run a recovery by pressing the F11 upon the HP logo then choose the SYSTEM RECOVERY. then simply follow the prompts to revive your computer to the original factory default. Do this a couple of times. If this will not work then most likely the recovery partition is deleted or corrupted. If you can still see the HP RECOVERY IMAGE, then go to START > COMPUTER / MY COMPUTER > right click and choose MANAGE > DISK MANAGEMENT > look for the HP RECOVERY IMAGE > right click and choose > SET AS ACTIVE PARTITION, then reboot the computer then simply follow the steps for the recovery.
Apr 22, 2011 | Computers & Internet
Error message "load needed dlls for kernel"
1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer.
Mar 05, 2011 | Acer Computers & Internet
How do i reboot my compaq destop to factory setting
you can do Recovery on the pc which will take it to the factory settings >> for Win XP pc >> keep tapping F10 button repetedly when you start the pc ... it takes you to the built in recovery partition.. select recovery and then run a recovery
>. for Win Vista >> keep tapping the F11 button when you start the pc .. takes you to recoery manager ... select Advanced option ... from there select system recovery and then click on next .. just follow the instructions on the screen
Mar 20, 2010 | Computers & Internet
Loading errors, after reinstalled recovery disk
BEST SOLUTION:
it might have corrupted the NTLDR thats the windows loading file system...
plz...do the following :
>>put the windows XP disk..
>>restart the system>>hit F2 or DEL as soon as system starts..
>>change the 1st boot device menu to CDROM...
>>then restart the system and hit any button as soon as it says "click any button to boot from CD"
>>system will boot from CD and windows setup will come up....
(CHECK THE LINK www.windowsreinstall.com)
>>hit R for recovery console to load....
>>then hit number 1>>
then it will show as C:>
>>type bootcfg /rebuild
>> follow the steps and then after it has been completed >> type exit
>>restart the system normally
May 11, 2009 | Computers & Internet
Dwt 1905 tv stuck in game mode
Comcast universal remote code for dwt 1905 is 0171, just tried it, it works
Nov 26, 2007 | Durabrand DWT1905 TV
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
