Question about Yamaha Music
My problem is that my psr2100 sound is making noise and automatic change scale plz solve my problem
Nashville tele that has the g string sounds off when playing
if you have the adjustable bridge try moving it back a little bit. the g string is a heavy string and will tend to go sharp when you have the string height up a little. make small adjustments usually only one turn or half a turn at a time. take care to note your adjustments so you can always go back to where you started. turners are nice but the ear doesn't lie. if it sounds right it's right
Jan 19, 2012 | Fender American Deluxe Telecaster
I have a problem with my behringer b3031a truth studio monitors.Slightly before a sound it's played (and during the playing) they make a little buzz. Ex. I turn on Windows Media Player and as long as...
The fault is not with the speakers... It is with the noisy audio system common in computers. Get a decent USB audio interface and use balanced interconnect cables to solve the problem.
Aug 02, 2011 | Behringer B3031A 2-Way Active Studio...
There is a high frequency noise in my sessions. I am using a Lexicon Alpha interface with Cubase 5 but now I can't record because of the noise. How can I solve this problem?
Make sure you are using BALANCED cables either XLR or TRS. Make sure ALL interconnected equipment is powered from the same receptacle. Make sure the level to the Lexicon is line level as using excessive gain at its input will admit noise.
Jul 28, 2011 | Lexicon Alpha Personal Recording Studio
I have a Peavey 8600 amplifier. It sounds great but when only operating vocals, in order to get the highs of your voice just right, the speakers put off a large amount of white noise. While singing, you...
There is not enough info here to provide a complete answer, but let me give you some background:
There will always be some hiss. This is due to general amplification where a small amount of noise is amplified along with the general signal. In most cases, the signal is strong enough to overpower any noise that is present (vocals in your example). This noise should not be that noticable in normal cases. If there is an automatic gain control in the line, this could account for it as with "silent" times, the gain will automatically be increased potentially to the degree where the noise is noticable.
Barring that scenerio, if the input signal is too low, the overall gain necessary to produce reasonable volume at the speakers will also be such that the noise is noticable. In order to track this down, please provide details about the current setup including:
1) Microphone make and model being used
2) Input being used on the mixer
3) Gain level being used for the mic channel
4) Gain level being used at the master level.
Dan
Jan 07, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Lowrey catillion organ with loud static noise
Try posting on the organforum.com.
It sounds like the power amp has a problem. Probably filter capacitors have gone bad.
Oct 24, 2009 | Music
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
When playing notes on the A string I get a crackeling noise
Just a thought:
If you used the speakers with another amp and they still make noise when you play certain frequencies, then it is obviously a problem with the speakers or the cabinet - it could be a mechanical resonance in some part of a speaker / cabinet, something like a loose screw or a nut, loose protection mesh on the speakers that resonates at certain frequencies, possibly a bad speaker or a speaker membrane...
Also, you might want to check the pickups on your guitar, see if the pickup core slug under the A string is much closer to the string than the other slugs so it is either picking up too much signal and distorting it or the string might be touching the slug when you play it and cause noise, also see if the string is touching something else when it vibrates...
good luck
3rq8 (Triarcuate)
Sep 08, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Hii
Hi
Find out the make of your sound card in control panel/system and either Google the manufacturers website and see if they have a download section or go to http://www.soundcard-drivers.com/ and see if the make is listed there
Cheers
Dave
Sep 27, 2008 | Music
Music Logo
15 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
