Question about Admiral AW22 Top Load Washer
Mildew smell in my toploading Admiral
Everytime I use this washer ist smells of mildew, even after using bleach. is the a cleaning process I should be doing or a water pan that needs to be emptied. I hate this washer because of this. I bought a top loader with the idea I would not have this issue.
2 Suggested Answers
  • 1073 Answers
SOURCE: Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Posted on Apr 10, 2008
Clothes smell after washing cycle
Nice, or not nice?
To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
How to Get Rid of Mold Smell in Front Loader Washing ...
www.wikihow.com > ... > Housekeeping > Cleaning > Laundry Jump to Preventing Smells in Your Front Loading Washing Machine - Part 2 of 2: Preventing Smells in Your Front Loading Washing Machine.
how to get rid of a bad smelling high efficiency washer ...
wholelifestylenutrition.com/.../learn-this-tip-say-goodbye-to-bad-smellin... Learn this tip and say goodbye to bad smelling HE washer machines forever! ... Not only did it smell moldy and musty but my clothes were starting to smell this ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Your Washing Machine Smells, and How to Clean It
laundry.reviewed.com/.../why-your-washing-machine-smells-and-how-t... Add this solution to your machine's detergent container, pour two cups of white vinegar into the drum, and run a normal load at high heat. The baking soda and vinegar should break up any residue stuck to your drum and kill any mold that might be present.
Washing Machine Smell on Pinterest ' Smelly Washing ...
https://www.pinterest.com/explore/washing-machine-smell/ Great tutorial on how to clean your front load washing machine, get rid of mold and mildew and prevent it from returning. I clean mine after every wash (a little ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Why Does My Washing Machine Smell Like Mildew? - Real ...
www.realsimple.com/home.../cleaning/.../mildew-smell-washing-machine To get rid of the mildew odor, run an empty machine on the hottest setting with bleach or Affresh ($8, homedepot.com), a cleaner that deodorizes a washer's interior. And after each load of laundry, leave the door ajar to allow the interior to dry.
Jan 09, 2016 | Washing Machines
This sounds like the pump is clogged up or the drain hose from the pump is retaining debris. The pump is easy to remove and check. There is a video at www.appliancehelponline.com/servicemanual.html check the video on how to take apart a direct drive washer. This will walk you thru the disassembly and the pump removal.
Apr 09, 2010 | Roper RAS8445KQ Top Load Washer
Mildew smell in washer
there is a chemical you can get to help with the smell from SMELLYWASHER.com
Feb 19, 2010 | Kenmore 22942 Top Load Washer
What is the issue with mildew and how do I address it? My laundry never smells clean
Any washing machine will grow mold & mildew when there is moisture in it and the door is shut. When you do a load of wash, the smell transfers to the clothing. To eliminate it, run a load just water & chloring bleach. This will kill the spores. Adding a little color safe bleach to each load or leave the door open when not using the washer will keep the problem from coming back.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wet clothes after spin cycle and bad mildew smell. I have seen many complaints about mildew smell with He3 & He4 well really frnt loaders in general. The bad mold is so gross and the smell is horrible.
Clean tub boot the best you can with bleach. Then run an empty load with sunlight automatic dish soap (verry little). Then this should clean and freshin the washer up. The best thing to do is not to shut the door on washer when not in use.
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Mildew smell in LG front load washing machine
even wityh a septic tank you can use bleach. the amount will be so little in regards to the amouny of bacteria in your tank it should not harm it when you do it once per mont. Take to filter out in the front though and clean it good. Should be located at the left bottom front
Aug 10, 2009 | Washing Machines
Hi, I have a hoover front loading washing machine and inside the drum seal there was a lot of mildew as I accidentally left some damp tea cloths inside the drum and the machine wasn't used for 2 weeks....
Run your washer with 2 cups of bleach, maximum hot water. After it starts agitating for a minute, stop the washer & let it remain for 2 hours. Then continue the wash.
Apr 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
LG washing machine has AWFUL mildew smell
Same problem and I was told to only use detergents with "HE" on the front of them for high energy. the soap without HE is too foamy and hence never truly drains out and causes a mildew smell. I also purchased something called "A" Fresh that I run in the washer every 6 weeks to keep the smell out. I got it at an appliance store for about $11.00 for 3 tablets
Sep 04, 2008 | LG WM-2277HW Front Load Washer
Kenmore washer smells/mildew on rubber
The smell problem is actually because of the softener....its nassssty stuff it coats the interior of the washer and forms a grease like residue. I would use Washer Magic (available at all appliance parts retailers) (only half the container in front loaders) and a hot wash. Also keep spraying the boot with bleach and water soluiton every few hours it will dissappear after awhile. please rate my help
Oct 04, 2007 | Kenmore 44102 Front Load Washer
Admiral AW22 Top Load Washer Logo
14 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
