Question about Kenmore Elite 45986 Front Load Washer
Washer won't start....just beeps 3 times
There is a little black sensor pin on the at the 2 o'clock position on the door frame. It got broken off so then I glued it back but now because of the glue it got stuck in the in position and now my washer won't start because I guess it thinks the door is closed. I'm trying to order the part #8181652 because that looks exactly like the piece I need but when I check model compatibility it doesn't match.....HELP me please
  • 32 Answers
Yes, door strike and if it is stuck inside the door latch that will have to be replaced also, unless you can pull it out. Part# 8182634
Posted on Apr 20, 2014
Testimonial: "Thank you! I did have to change out the whole door latch piece....I drove out to get the part yesterday but didn't realize I needed a torx driver to remove screws so finished the job today."
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: won't drain or spin
If this is a Kenmore top loader, the most common cause of the symptoms you describe is a lid switch malfunction.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, need additional assistance, please post back with your model number (located on a nameplate along the wash tub opening under the washer lid), so I can provide you with better assistance. I hope this helps you.
Posted on Jan 24, 2010
Kenmore elite washer will not start
The problem might be that the black pin (about 3/8" long and 1/8" in diameter), that normally sticks out of the frame of the washer at about the 2 o'clock position, and which is pushed in when the door closes, has broken off. If this pin breaks off, the washer will not recognize that the door has been closed. In my opinion, the pin is most likely to break when you close the door and the door was not properly aligned with the door frame -- in which case the pin will be sheared off. Let me know what you find.
Jun 29, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HELP! Very urgent! I have a Hotpoint Aquarius WD440 washer/dryer and the door handle has broken off. My clothes are stuck inside and I need them by tonight. How do I get the latch to open. I know I need to...
Slide a thin knife from 3 o clock door position against the frame to push the locking latch pin towards your left, only about a centimeter and the door would then release
Dec 21, 2012 | Washing Machines
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
On my whirlpool duet washer the little pin in the door (black) that pushes in when shut broke and now my washer wont kick on
Is this pin on the door or the frame? If the frame then you need a new door lock assembly that you replace by peeling back the rubber tub bellow after removing retainer spring.
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Kenmore model 110.42832.201 won't start, door won't lock - cycle selection button just flashes.
Hi, check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Take care
Jul 19, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not start
That sounds like your door latch. In the door frame where the door is secured, you should see 2 black pieces in your door frame. The bottom one (square in shape) receives the pin sticking out from the door. The upper one (round in shape) should have a pin sticking out of it from the machine. This is the machines way of detecting wether or not the door is still open. If the pin gets broken off, the machine will not run. It is easy to get snagged when putting in or pulling out laundry. I have had customers who have simply found something to super glue back on so it functions like the missing pin again, however I don't recomend bypassing this as it is one of two systems that keep the machine from flooding your house if the door doesn't stay closed. Bluntly, if you can't jury rig it right, just replace it.
As far as replacement, remove the 3 #20 torx screws holding it in. Remove the clamp around the front grey rubber seal. (pring it off with a small, flat head screw driver works well. Pull around the edges and the seal will come off. Reach to the right hand side and you will feel your latch. Lift slightly up on it (there are 2 clips it sits in, then pull slightly toward you. There are 3 connectors that have to be removed (don't worry about the order, they all only fit back in 1 way). Push on the tabs that are holding them in to remove them. Replace the latch assembly with one you have purchased from the manufacture on line or from a local appliance parts store. (you will need the model number of your washer located in the door frame for this at either place). Now place the 3 connectors back in. Put the assembly back into the tabs inside. Re-attach the torx screws. There is a gap in the grey rubber seal that the metal lip of the washer sits in. Re-seat it. Now place your small flat head screw driver in one of the holes next to the spring on your clamp. Again, there is a gap on the seal it fits it to keep it tight. Work it back in keeping 1 hand on the screw driver and moving a round object (screw driver handle) around the edge of the clamp until it is seated all of the way around. You should be all set.
Please be sure to rate this information if it was of help to you.
Jul 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kemore HE3 front load washer won't start
Check you door latch. When you open the door, there should be a black square hole on the frame and a black round hole above it with a pin sticking out. The pin is probably broken off and the door latch assembly needs to be replaced.
Jun 03, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
116 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
