Question about Troy Bilt 175HP Manual 42" Riding Mower
Turn key starter wont turn over engine
My mower will not turn over, alls you hear is starter noise
    Scholar:
    New Friend:
  • 82 Answers
Sounds like the battery is too dead to start it, try charging the battery to see if it improves. Check the battery connections to make sure they are clean and tight. Hope this helps
Posted on Apr 20, 2014
92 subaru loyal wont turn over and makes humming nouise in cab
If the starter does not engage you will hear the "growling" in the cab which is usually the fuel pump and is a normal noise, more apparent because of the lack of engine noise. First thing to check is the wiring to the starter under the hood. If it is ok could be contacts in the starter solenoid , starter brushes or a"dead" starter. I would try tapping the starter with a SMALL hammer or the end of a I/2 inch breaker bar while having an assistant turn the key to attempt starting. Stand on driver's side, If spare is mounted under hood, remove spare. The starter is visible and can be tapped from there.
Feb 10, 2014 | 1992 Subaru Loyale
I pulled the starter,alternator & battery they all checked good and ity still wont turn over what could it be?
If you can hear the starter click or engage when you try to start . Either the battery has low voltage or the engine has seized. You can check the engine by putting a wrench on the crank pulley bolt and try to turn by hand.Make sure to disconnect the battery first. If the engine turns it's good. If the starter is making a loud grinding noise but does'nt turn the engine. It's your flywheel/flexplate. Also make sure your battery connections are clean and tight for proper voltage delivery. I'm not sure if your car would have a fuse or power relay for the starter,but it might be worth checking out. If you do not hear a click from the starter when you turn the key it could be a short in the ignition switch.Not the key tumbler,the electrical switch is behind the ignition key tumbler. Hope this helps. Other than this you may need a repair manual to trace the wiring of the starting system and fusable links.
Jul 25, 2011 | 1994 Oldsmobile Cutlass Ciera
I have purchased a Toro zero turn mower and can't get it to start. It has gas, I charged the battery. It makes a clicking noise when I turn the key but motor won't turn over. Is there any special way to...
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Jul 27, 2010 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
My car wont start battery is not dead,but wont turn over?
if the battery is fine check if you hear a clicking noise coming from the starter motor when you turn the key to try and start the engine.
If you hear this noise then this is a good indication that the selenoid has failed meaning you need to replace the starter motor.
You can give the starter motor a hit with a piece of wood as some times this will get the starter motor working just to start the car but this isnt a permanent fix and could leave you stuck if you used the car.
Now if the starter motor isnt clicking but you hear a clicking noise coming from either the cars fuse box or the ecu when you turn the key to start the car then this would indicate a problem with the imobiliser this would need testing using a diagnostic machine as their is no other way of testing this to find out if its at fault.
Let me know how you get on or if you need further assistance ok
Dec 22, 2009 | 1996 Chevrolet Cavalier
My 1996 Chevrolet Blazer won't start most of the time. Engine don't turn over, or the starter when I turn the key. All I can hear is some clicking coming from the carbarator & a humming noise under my...
The humming noise you hear is the fuel pump. It is probably your starter soleniod. If you hear an electric click under the dash near the steering column when you turn the key then the ignition switch is ok and your starter needs to be replaced. This happened to me last month.
Dec 08, 2009 | 1996 Chevrolet Blazer
My 1995 mazda 626 4 cyl wont start. its getting gas spark. when you turn the moter over you hear like a muffeled noise at the moter not muffler
Your problem could be a lot of things ,,without hearing the noise we have to gess your problems like
1Chech the engine for turning over if not then its the starter bendix slipping and if it is turning over as usual then its could be the starter ring on the flywheel and if so turn key off and turn engine over by hand about 1/2 way around on bottom pully and try starting again and if it starts then its the starter ring.
Engine or Gearbox out job.
Let me know how you get on . Ron
Nov 11, 2009 | 1995 Mazda 626
98 chev blazer wont start or make any noises...
Listen for a click from under the steering column when you turn the key on. If you hear no electrical click then your ignition switch could be bad. If you hear an electrical click the you starter soleniod is bad.
Jul 13, 2009 | 1998 Chevrolet K1500
Troy Bilt 175HP Manual 42" Riding Mower Logo
132 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
