Question about PfaFF Tiptronic 2040
Vibration with needle mechanism
When I start machine needle mechanism fibrates rapidly. Will stop after a bit and sews just fine. Have had it serviced and it still does it. Any solutions?
  • 323 Answers
SOURCE: pfaff sewing machine
You don't have the thread in the take up lever or it is not in the tension. Rethread it , Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.
set your tension to 5 and try it.
sewman7
Posted on Jun 18, 2008
sew dutch
  • 24 Answers
SOURCE: machine stops sewing when I hit a thickness
And when the fabric is thick, you can help the machine by putting some thick fabric behind the needle, so your sewing foot is level, then you will avoid breaking the needle.
Posted on Jul 29, 2009
  • 632 Answers
SOURCE: PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
Posted on Aug 10, 2009
  • 632 Answers
SOURCE: Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Posted on Jan 05, 2010
SOURCE: My pfaff Tipmatic 1151 started skipping stitches on knit fabrics using any size needle, even pfaff needles. It sews fine on non-knit fabrics using size 14 or larger needles. I have checked all of the
are you using a ball point needle sewing knit or stretch?
Posted on Dec 19, 2012
Does the Innovis 1200 ha be e a reset button? I was sewing and the needle hit a pin. It stopped sewing and the needle just vibrates and the machine won'the sew.
Turn the machine off. If you haven't already, replace the needle. It may help to remove all the thread from the machine, clean around the bobbin area, and then rethread the machine. If the machine still will not start, you may need to take it for service.
https://www.manualslib.com/manual/250262/Brother-Cps5xvy.html?page=184#manual
https://sewing.patternreview.com/SewingDiscussions/topic/37182
Mar 18, 2017 | Sewing Machines
We got Juki DDL8100E. Few days ago. when sewing, needle broke and since then our machine is making heavvy noise. Also, the Stitch adjuster knob is vibrating up and down. please help
check that a bit of the broken needle is not interfering with the bobbin case movement
if the breakage was hard enough it may have altered the needle / hook timing which will cause a knocking sound as well
Aug 20, 2016 | Juki Sewing Machines
Why does it make a knocking noise as it sews?
the needle position is up tight in the holder and no where else
the cut away bit of the needle faces the bobbin case hook and the groove in the needle faces the end of the machine and gives clearance for the thread to pass through the material
from your description and what you did, the needle /hook timing needs adjusting as it is out
turn the machine over by hand as in sewing and watch the position of the eye of the needle and the bobbin case hook
just as the needle starts to move up, the hook should be just above the eye of the needle at the edge of the needle
The adjustment is by loosing off the screw on the vertical shaft at the end of the machine that is attached to an arm that moves the needle up and down and move that bit up or down until the needle is positioned correctly to the hook
tighten up the screw
next is to check the needle tension is not too tight
workshop manuals are available on line in pdf version or take it to a sewing machine repair shop for a proper diagnosis
May 12, 2016 | Singer Stylist 7258 Electric Sewing...
Blowing fuses. Get a vibration first
If you've checked all of the 'usual' things (cleaned, lubed the machine according to mfg. directions, new needle, etc.), take all of the thread off and try sewing for a bit without it. Same symptom? Take it for service!! Could be faulty wiring. If not, your tension may be *way* too tight. Try loosening it up a bit, first the upper tension then the bobbin, but adjust slowly - it's really easy to miss the 'sweet spot' for tension.
Hope this helps.
Sep 10, 2012 | Janome Memory Craft 9000 Computerized...
Why does my new Singer cg-500 stop working, then start for a little bit and stop again?
Probably thread wrapped around something....takeup crank, motor pully...if you can get inside to have a look great, if not, find someone who can.
Oct 25, 2011 | Singer CG500 Mechanical Sewing Machine
My cousin has a machine that straight stitches fine but skips when you zig zag. I have changed her needle, dust out underneath, made sure that it was threaded correctly, changed thread. My question is...
Yes, it sounds like you've gone through all the usual trouble shooting so timing is probably out just a bit which means that the needle and rotary hook are not getting close enough to each other during the zig zag.
Probably best getting a sewing machine technician to give it a service and reset the timing.
Jun 28, 2011 | Necchi 4575 Mechanical Sewing Machine
Needle is not picking up thread from bobbin it was working fine and just stopped sewing then I noticed the bobbin thread was not being picked up .
Check your needle, it may need to be changed (make sure you insert it flat side away from you), now totally rethread, Another thing, is your thread old, tangled? If, all of this does not fix it, take it in for professional service.
Apr 16, 2011 | Brother LS-2125 Mechanical Sewing Machine
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
Sewing happily on any material when suddenly the neadle hits metal and bends or worse snaps.
Be sure to have the right needle for the right material! that sounds maybe a bit like I am taking you for a ride! but not! I sew professionally and have a box full of needles! Most of the needles you buy in the shop have a designation (jeans, jersey etc! ) afterwards there is something like 70, 80, 90 up till 100!
70 - very fine fabrics, silks and sheers
80 - fine fabrics, thin cottons
90 - average and 'normal' fabrics
100 and more - thick fabrics, curtains etc!
If your problem persist, you may need to take your machine for servicing! how old is it? and what brand? yours,
rick
Oct 27, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
19 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
