Question about RTO Automatic Transmission And Engine Oil Pressure Tester
I drive about tens miles and then the over drive turns off
Over drive problems con drive ten miles it turns off ill stop and wait about 20 minutes it will do the same thing
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 99 Answers
Your trans is running hot or the solenoid for OD unit is bad or going bad. You need a diagnostic tester to read the trans info as your going down the road. It could be a faulty trans temp sensor shorting out and the trans thinks it is over heating and turns the OD solenoid off. More likely however the trans is running hot. This usually means the trans cooler is plugging up and or radiator is partially plugged. There are to many factors that can create this problem, some cheap repairs others expensive. The computer turns OD off to maximize cooling to move as much trans fluid as possible thru the cooler. In OD only a minimum amount of fluid is sent to the coolers as OD is a mechanical lock up of the internal gears with no slippage, not like other gear ranges in an automatic. Slippage generates heat, the fluid is used to stop the clutches from burning out and carry heat away from them.
Posted on May 08, 2014
Put in a new fuel pump car still won't start has a security light on what do we do to get it started
If the Security Light is on but is not flashing, the security system is fine. If the security light is flashing then turn the ignition key to the run position (do not start). Wait over ten minutes and then try to start the engine. After the ten minutes you should notice that the light stopped flashing. If the engine starts then you do have a problem with the Passlock Security System.
Feb 28, 2014 | Mercury Grand Marquis Cars & Trucks
My box360 takes about ten-20 minutes of "open
Open tray when a game is in is the dvd drive going out on it....
Jun 03, 2013 | Video Game Consoles & Games
I have 06 Sonata and when my ESC light comes on I can't drive my car at all. I have to pull over with my hazords lights on and wait for about five to ten minutes until something happens. Its reall
When a warning light switches on because of a fault, the fault should be recorded in the computer memory and suitable diagnostic equipment should reveal approximately what is happening.
Aug 05, 2017 | 2006 Hyundai Sonata
I believe my 1994 Dutchmen has the 5.9 L (a 230hp I think? 100K miles) Someone jsut told me to warm it up for 5 to ten minutes in the morning...I couldn't understand the manual only mentioned starting. Do...
well i never warm my car up in the mornings its all down to how you drive it, if you flog the nuts off it its going to were out a lot faster if cold but drive it with some cear do oil changes on it often and it will last at least you another 100,000 miles as for the rattles
all motors do that at 100,000 miles lets fase it how much would you rattle if you had walked that far?
just drive it with a bit f tlc and it will get you there
Dec 29, 2009 | 1994 Dodge Dakota Club Cab
1994 FXDL misfires for ten minutes of driving
Start with a fresh set of spark pulgs, adjust your choke or open it a bit as it warms up.
Aug 22, 2009 | Harley Davidson FXDL Dyna Low Rider...
AC Fan not working on Auto
ac can take up 2 ten minutes to reconize commands be patiant and stop pushing buttons wait desired ten minutes if does not solve problem faulty conrol box and if comfort cortol thermo try reset in owners manual
Jul 23, 2009 | Dometic Rooftop RV Air Conditioner
Try to start the truck, must wait ten minutes
imobilizer is faulty. get it checked out.
Jul 18, 2009 | 1999 GMC Sonoma
93 honda wont start after driving for a few miles
I have the exact same problem. I gotta wait until the D light stops blinking to be able to start my car. I'm trying to figure out this too, but so far I've been able to start my car by simply disconnecting and reconnecting the spark plug wires. Also I shift my car from P to D then back from D to P. I usually wait about 5 minutes before I can start my car.
Also, don't try to start your car when its blinking D. i tried that before and my car started but it had extremely low power, and my entire car started to shake violently. I had to bring it to the mechanic after that, he said it was a fuel injector problem but I dont believe him.
Jul 31, 2008 | 1993 Honda Accord
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
50 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
