Question about TMI Products Vizualogic Headrest Pair w/DVD GM 03-Up Light Neutral Car Video Player
Monitor will not shut off, goes to a white screen
When i shut off the monitor it goes from a blue screen to a white screen but stays on
  • 23 Answers
Your unit isn't grounded..Check your main pin connector cable to make sure the connections are tight
Posted on May 11, 2016
Pandigital novel white stuck on blue screen
everytime i turn on my pandigital tablet it goes to blue screen and stays on there, until the battery dies, everytime you turn it on it goes to the blue screen and stay on there what should i do?
Mar 02, 2012 | PANDIGITAL Novel 7
My Hewitt Packard flat screen monitor keeps shutting off, it will come back on then shut off again.The green light stays on.
my HP w1907 flat screen keeps shutting off after playing a game, but does it frequently when changing browsers also.The blue lite stays on, if I click and return it back on blue the monitor opens for one second.
Also I can't return the screen resolution back to its original setting, which is 1440x900 because any browser home page has a 4"white space on both sides of the monitor. I can't hit my auto selectbutton because that causes the problem. I spent $60.00 for tech support but no help on fixing the problem. One tech directed to buy hardware helper,that was about$30.00! I just keeps directing me to my original chipset setting which I told the tech that's where my problem started! My daily important update keeps popping up with it,so where's the HP support when you paid for it? Problem still not resolved. Joe...aka jljoekool@charter.net,,I bought the HP monitor and tower together,so it's a HP PROBLEM
Dec 12, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Samgung pc monitor has a plain white screen when turned on. Also goes off after a short while and the blue power button blinks.
plain white screen means loose conecting the lvds cable to panel. reconect it.
if its goes off then check power board +5v or +14v filter capicitor.
Feb 17, 2010 | Samsung Syncmaster 940BW LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Dell monitor goes white when computer shuts down
does the monitor stay white after shut down or does it go back to a black screen?
Jun 26, 2009 | Acer Aspire One PC Notebook
Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
White monitor
You can degouse it.I think you placed your monitor in any magnetic field or near fan ac or any electric equepment.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | Xerox XA7-172i 17" LCD Monitor
Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Nov 19, 2005 | Sylvania L181 18.1" Flat Panel LCD Monitor
TMI Products Vizualogic Headrest Pair w/DVD GM 03-Up Light Neutral Car Video Player Logo
145 people viewed this question
Top TMI Products Car Audio & Video Experts
greg benton
richie46
Tommie Jones
Level 1 Expert
Are you a TMI Products Car Audio and Video Expert? Answer questions, earn points and help others
