Question about Samsung Style ST66 16.1 Megapixel Compact Camera - Red 2.7" LCD - 5x Optical Zoom - Electronic IS - 4608 x 3456 Image - 1280 x 720 Video - PictBridge - HD Movie Mode
There's corrosion on my battery in my camera
I left my camera out on my dresser for quiet a long time. When I went to use it the inside had corrosion on the contacts and battery. I don't know what else to do. I've tries picking off the corrosion with cotton swabs, but it didn't work very well. Anyone have an answer for me?
  • 50 Answers
You can try using alcohol pad and a piece of plumbing sand paper (or any fine grit sanding paper with cloth backing). Make sure you get all corrosion off of battery and contacts to camera. After using alcohol pad wipe down with a dry cloth to remove any residue.
Posted on Apr 20, 2014
Canon Powershot A530 camera died. Worked fine yesterday and then went to take a picture and the lens extended then the camera died.
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 21, 2010 | Canon PowerShot A530 Digital Camera
My digital camera will not switch on even with new batteries, before it went off the zoom lens would not retract either.
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Jan 06, 2010 | Cameras
I made the mistake of buying another Kodak camera and this one is only 9 month old and only used 3 time in that time. When you turn it on it turns right off. I put in new battery and the same thing...
Batteries tend to deteriorate and leak over time, especially if left in a camera when it's not used for several months. Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 15, 2009 | Kodak MX1063 Digital Camera
My lithium ion battery will not recharge
How long was the battery left in a flat condition?
Usually a flat battery does not damage the camera unless the dead battery leaks fluid inside the camera and causes corrosion problems.
Try a new battery and check the charger with a multi-meter, the voltage of the charger should be slightly higher then the voltage that is printed on the label on the bottom of the charger.
Nov 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
The battery went dead, we charged it back up now the screen is black and when you take picture it is all black, but i can look at previous pictures. Canon Power Shot SD1000
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Oct 30, 2009 | Canon PowerShot SD1000 Digital Camera
Cant seem to power up for only 10 sec and a ? flashes in bottom left on screen
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
The lens on my casio exilim ex-z20 is stuck.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 14, 2009 | Casio Exilim EX- Z200 Digital Camera
I left the battery more than a week in my camera and now I changed new battery but still not turn on What shall I do? It was working before even I keep battery for long periods.
Oct 11, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
It wont turn on ,it is charged , went on yesterday ?????
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe the ends of the batteries and replace them in the camera. This clears up the problem about 90% of the time -- I hope it works for you.
Sep 09, 2009 | Kodak EasyShare Z1015 IS Digital Camera
Turn on camera
This problem is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts with a soft dry cloth (a heavy corrosion buildup may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any cleaning residue from inside the camera, then clean and reinsert the batteries. This clears the problem about 90% of the time.
Aug 23, 2009 | Kodak Z8612 Digital Camera
Samsung Style ST66 16.1 Megapixel Compact Camera - Red 2.7" LCD - 5x Optical Zoom - Electronic IS - 4608 x 3456 Image - 1280 x 720 Video - PictBridge - HD Movie Mode Logo
26 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
