Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Can you run the pool heater with the AO code flashing
The AO code is flashing on my pool heater. Should I turn it off or let it keep running? I don't have a manual for the heater.
  • 3 Answers
It will not run with AO code. That is telling you something is wrong/blocking the combustion fan from satisfying the safety switch. If it is a brand new heater this usually means the correct voltage has not been set in the heater = you would need to check what you have and then check setting. Doing this incorrectly could completely destroy all electronics in the heater.
If this is a heater startup for a new season the rubber tube from the combustion fan to the blower switch could be off or damage by rodent bites.
If this heater is older it could be a clogged heat exchanger which is a much bigger repair or problem for a homeowner.
manuals are available on haywardpool.com
Posted on Apr 26, 2014
  • 366 Answers
SOURCE: AO error
This error is produced when the blower prover switch does not close after the blower starts, the control will stop the ignition and go into lockout. Automatic reset is immediate after the blower prover switch closes.
If you keep having this problem, contact a reputable service company, especially if it's under warranty.
The link to the owners manual is below, it references fault codes, etc..
Hope this helps.
http://74.125.95.132/search?q=cache:4mAdY7bLfoQJ:www.haywardnet.com/products/Manuals/pdfs/Manual227.pdf+hayward+AO+error&cd=7&hl=en&ct=clnk&gl=us
Posted on Sep 16, 2009
john224
  • 1378 Answers
SOURCE: blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Posted on Jan 04, 2010
  • 4 Answers
SOURCE: I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Posted on Mar 01, 2010
Testimonial: "Thank you very much for the assit. I did find a kink in the vent safety switch. Thanks again."
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
  • 7 Answers
SOURCE: Pool Heater will not light. (Flashes AO)
Mine had this problem, removed the blower and manually rotated the shaft. It was stuck, but once freed it runs fine.
Posted on Jun 11, 2011
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Error AO ON MY HAYWORD H SERIES POOL HEATER
The AO mindicates an open prover switch ,, here from Hawward site .
If the blower prover switch opens unexpectedly during operation the control will
shut down and attempt to re-light. If the switch does not close after the blower
starts the control will go into lockout with the blower running. Automatic reset is
immediate after error is corrected.
If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic
reset is immediate after the switch closes.
May 08, 2010 | Hayward H Series Pool & Spa Heater 400k...
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
Blower runs but no ignition then AO error code
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
AO error
Hope this helps.
Sep 16, 2009 | Hayward H Series Pool & Spa Heater 400k...
If you hear the blower come on, then you have an air sensor problem. Hopefully the air hose popped off, or has cracked...If not then you will probably neet to replace the air pressure switch.
Mar 15, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
139 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
