Question about Whirlpool Washing Machines
Whirlpool washing machine powers on, pumps some water out at the beginning but then it stops. Power is on, water is on. Thought maybe its the solenoids not letting water into machine. How to test them? Cheers.
  • 30 Answers
Does it empty the all the water?
Model # would help
Posted on Apr 26, 2014
  • 20 Answers
Hi. This might sound like a really silly question but have you checked if the program control dial has been turned to "Z" which is the feature on most machines to empty the drum of water and not do anything else?
I came across this problem with a friend when one of the children was playing with the program knob!.
Posted on Apr 22, 2014
Testimonial: "Hi, thanks for your interest, unfortunately its one of the older models and has no "Z" feature. Cheers"
  • paul clark May 04, 2014
    Ok, no problem, I hope you get it sorted.
    New Friend:
  • 20 Answers
Hi, does this happen with the water selector switch set at high level, or any level....maybe the screens are blocked in the solenoids , from trash from water. The only way I know to test the solenoid, is to apply 115 volts to the connectors of the solenoid, leave all the hoses hooked up, water hose's, make a cord with connectors that fit the solinoid, and plug it into your power otlet and see if the water comes in, if so its in the machine, like the timer, or water level sensor.
Posted on Apr 20, 2014
  • 1 more comment
  • sifarcher Apr 20, 2014
    No trash in screens. will look at the timer and water level sensor.
    Thanks!
ERR code
Inside the machine is the tech sheet with all the info you need. It maybe just under the top or down along one of the sides but it is in there
Mar 29, 2014 | Whirlpool Washing Machines
Whirlpool adp 9411
If this is the machine with just a knob for the wash cycles, and one button to start the wash cycle, you will have to replace the timer. There is no reset that I know of.
Dec 16, 2013 | Dishwashers
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash stops, beeping, flashing F and 02
I'll just take a swing at this one, without model number.............F-02 is typically a Whirlpool error code for " slow drain". If this is a Kenmore or Whirlpool front loader, pull off the bottom panel and check the pump filter, (pump should be right up front, turn counter-clock-wise to remove filter) clear of any debris, check hose from tub to pump as well. NOTE! If there is water in the machine, it will pour out of the pump, first remove the water either with a wet-vac, or just do it very slowly and carefully at the pump, draining the water into a pan.
Apr 21, 2009 | Washing Machines
Smelly water
? How about Filling the machine with a suitable detergent bleach solution leave a couple of hours then pump out. Also this is likely to be a grease/soap crud build up in the pump and drain system So attention to the drain hose, Detach and seal one end and fill with hot detergent and leave then remove the plug to allow to drain. It is the drain area most likely the cause.
Jul 28, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
Washing Machines Logo
222 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
