Question about Eureka Zuum Model ECV5400A Central Vacuum
How to clean permanent HEPA FILTER in ZUUM EUREKA central
The grey filter inside the unit is full of dust and the yellow light on the unit is ON and steady. Less suction is also observed.
reddevil6
  • 1673 Answers
SOURCE: my eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Posted on Jun 17, 2008
nwj2468
  • 76 Answers
SOURCE: dust blowing out of the side of vacuum
make sure that the filter in the dirt cup is in place.
Posted on Apr 19, 2009
SOURCE: No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Posted on May 24, 2009
SOURCE: Eureka Optima vacuum has suction at the hose but
The same thing happened to mine- it turns out the belt was broken! So just replce the belt- it's about $4-$5. Your manual should explain how to do this.
Posted on May 30, 2009
nwj2468
  • 76 Answers
SOURCE: new Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Posted on Aug 22, 2009
MAINTAINING A EUREKA BAGLESS VACUUM
Helo Reader,
You can purchase replacement parts directly from Govacuum with an exclusive 11% discount coupon only for Fixya.com readers, use code: FIXYA11 at checkout to avail the offer. We also offer free shipping over $35.
Eureka Style U Belt - https://www.govacuum.com/products/eureka-u-extended-life-belt-set-of-2
Eureka HF7 Filter https://www.govacuum.com/products/genuine-eureka-premium-hf-7-hepa-filter-with-arm-hammer-61850c-1-filter
Hoover parts - https://www.govacuum.com/collections/hoover
Jeethu
Govacuum Team
https://www.govacuum.com9_17_2017_3_49_04_pm.jpg
Oct 04, 2014 | Eureka Altima Upright Vacuum Model 2996AVS...
Where can I get a replacement filter for bap4010?
According to their website:
PERMAtech Permanent HEPA Type filter traps 99 % of all allergens and dust down to 1.0 micron.
PERMAtech Permanent Filter Never Needs Replacement!
Simply vacuum the filter every three months to maintain performance.
Requires less cleaning and maintenance than other permanent filter systems.
Built-in Ionizer assists in cleaning the air from dust and allergens.
Oct 10, 2011 | Bionaire PERMAtech BAP4010-U Air Purifier
Subject: Eureka Tru Hepa Wirlwind Amps Model 4383. Working fine then just stopped. Later worked fine again? What is/was the problem? Does it need a new filter?? also has the # 0108017529 on machine
I'm not sure all machines are the same, but many have thermal overloads on the motor that can only be reset upon cooling, so wait 30 minutes and try again.
Secondly, my vac has 3 filters, one in the dust tray that you empty, one under where that dust collector installs and the HEPA filter on the back.
Ensure that all three are cleaned.
Gary
Feb 12, 2011 | Eureka 7619AT Vacuum
What filters do i need for the eureka the boss bagless vacuum w/widetrack modal 4495
There is a Cassette Micron Filter 60696.If you have a HEPA cartridge filter you need EUREKA's HEPA part 61500.In earlier models there is a micron filter instead of a HEPA filter--for that you need EUREKA's Micron part 60801. But if you have that HEPA filter, the manual says you have to use the HEPA filter to achieve the closed HEPA filtration system again.
Dec 10, 2010 | Eureka 4495A Bagless Upright Vacuum
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Eureka vacuum won't stay running
There is a relay in the system. Based on your description it sounds like yours is bad. The cloth filter is a big pain to remove. I would recommend burrowing a shop vac from a friend and cleaning it that way.
Jan 16, 2009 | Eureka Luxury Family 8-Person 2-Room Titan...
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Eureka Zuum Model ECV5400A Central Vacuum Logo
153 people viewed this question
Top Eureka Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Eureka Garden Expert? Answer questions, earn points and help others
