Question about U-Line Icemaker
Water pouring out of the ice make - U-Line Icemaker
    Sergeant:
  • 446 Answers
Does it stop if you unplug it if not you need a new water valve
Posted on May 12, 2014
    Problem Solver:
  • 10 Answers
Repair, adjust or replace the float switch which cuts off water supply.
Posted on May 08, 2014
  • 3 Answers
If the water is pouring out from underneath, and you have a drain pump, check in back of the unit to see if the water tube has come away from the drain pump, therefore dumping the drain water on the floor. It happened to our unit because the unit moves a bit each time the door is opened or forcefully closed. Hope that helps!
My Liebherr ign 2566 freezer is having problems with the icemaker. It is producing ice cubes but also water is pouring direct into the tray therefore producing a big slab of frozen water.
Hello there,
You need to check the water inlet valve, it is having a problem, it is not shutting close after filling the ice maker with water. It is already defective hereby causing water to pour out into the tray therefore producing the big slab of frozen water.
You will have to test and replace the water inlet valve. That way, it will stop pouring water into the already made ice that is in the tray.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Liebherr Refrigerators
Water supply for ice maker won't turn off
Its either the water valve thats not closing, or the ice maker not telling the water valve to shut off.
Turn off the ice maker, and see if water still pours out, or even better, unplug the refrigerator and if the water still pours out of the ice maker, then the water valve is bad and you should have it replaced.
Jun 20, 2011 | Kitchen Ranges
No water flowing into the ice maker reservoir. I poured water into the reservoir, but no ice dropped after 10 hours. Next day I unplugged refrigerator opened freezer door and thawed it out for about two...
Well, if the ice maker were working properly, when you poured water, assuming you poured A, enough water, and B, not too much water, you should have seen some cubes drop into the bucket. But since you did not get any ice cubes, I would have to say the reason your ice maker is not making ice is because you have a bad ice maker. Its not receiving water because it is not cycling.
Oct 09, 2010 | KitchenAid KSRU25CR Side by Side...
My icemaker just stopped making ice - i can feel frozen ice in the top but it doesnt dump any ice out?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 13, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The ice maker just stopped making ice.
First , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve ( pt. # 4389177 ) . If it does not dump the cubes , replace the ice maker ( pt. # 4317943 ) . After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Dec 04, 2009 | Whirlpool ED2FHEXN Side by Side...
Not making ice unless I pour water in tray, water does not flow from small plastic line that feeds tray. I did clean screen at suppy line.
It could be the water valve or water switch in the icemaker. Now it doesnt call for water until the thermostat is satisfied.Now if you pour water and it goes thru and dumps into the bucket I would try to change the valve.
Sep 29, 2009 | U-Line Icemaker
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
Water keeps pouring into ice maker and doesn't shut off.
does water come into cabinet if the icemaker is unplugged? if so, the water valve is leaking thru and needs to be replaced
May 06, 2009 | Refrigerators
Ice maker pouring water
there must be something wrong with the solenoid valve that controls the water flow to the ice maker
Jun 14, 2008 | Refrigerators
U-Line Icemaker Logo
119 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
