Television picture turns off when warm
I have a Toshiba TP50F61 that works great except that after the TV has been on for an hour or 2 the picture will just go black. Sound and all else keeps working. If you shut the TV off for a few hours it will work fine again untill it seems to get warm and then again shut down.....any ideas?
  • 20 Answers
To me it sounds like a power supply board problem...some componet is breaking down intermitly ...that is a hard problem to fix, finding the board should be easy, but buying the board, replacing it, and still the posibily it be something else is really difficult..
Posted on Apr 20, 2014
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
After 11 years???? OMG This set is a tired pup and should be put to reast. My experience with older sets and your complains are all capacitor problems and is only gonna get worse as the first time around repair will take several capacitors to repair. This set has no user serviceable parts inside so you should not attempt a repair suchj as this on your own.. This repair if you decide to go through the first time will be About 300 to 600 bucks the first time and cost will continue to raise till the sets put to sleep. Good luck
Posted on Jun 01, 2006
SOURCE: No picture, hear sound, television will shut off after a few seconds.
Take out the bulb (back left hatch door) look to see if the element inside the bulb is broken or blackened - (replace bulb) if the bulb looks OK then it's the ballast that fires the bulb (service call).
Raf
Posted on Nov 30, 2007
  • 46 Answers
SOURCE: My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Posted on Dec 19, 2007
CrazyLarry
  • 173 Answers
SOURCE: tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Posted on Jan 26, 2008
SOURCE: blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Posted on Jul 02, 2008
TP50F60/TP50F61 picture won't come on for long stretches
If you need to hit the tv my money is on a bad solder joint. Re-flow solder on any suspicious joints.
Oct 08, 2012 | Toshiba TP50F60/61 TV
Picture scrolls constantly until it warms up after 1/2/hour
the problem on ur tv is the hipper board , this board controls the aligment and color on ur unit , but the only problem this board is not longer avelible ,
Dec 01, 2010 | Toshiba 50H13 50" Rear Projection...
Hello..Toshiba 51HC85, 2005 model. Turn on TV and verticle wavy lines appear until TV is warmed up completely. After warm up the picture is great again. Any ideas?
I've had the same problem for about the last 6 months. My workaround which was to leave the tv on 24 7 and just turn off the TWC service box. But now the symptoms are vertical dark lines going all the way across screen. My guess is that it will cost more to fix than worth it. I paid @$2000 for it new in 2004. Technology has gotten better so I may just go out and get a Samsumg for considerably less and be way better off. None of Toshiba's products had done well for me. 2 laptops, 3 tvs, etc. have taught me this.
Sep 20, 2010 | Toshiba 51H83 51" Rear Projection...
53SDX20B Projector TV - No Picture
It was condesnation from moving the TV from the cold outdoors to the warm indoors. I let it warm up for about 2 hours and then it was fine.
Jan 11, 2010 | Hitachi Televison & Video
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
TP50F60/TP50F61 not working; no picture or sound;
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 11, 2009 | Toshiba TP50F60/61 TV
Toshiba 43AX60: sound but no picture
try switching to a different video source and play a DVD or a game system. If the issue is still there try unplugging the TV for 5 min. and then plug it back in.If the problem works fine on all other devices except the video source that has the issue try hooking up the same device your having the issue with to a video source you know works if that works then you have a bad video source on the back of the TV, if it does not work it's either the cable going to the TV or the device itself.
Jul 08, 2009 | Toshiba 43H70 43" Rear Projection...
Scrambled picture
I have the same problem here as well, except that it has been happening so long that now it doesn't get completely clear. The picture was great at one time :-(
Jul 07, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba Projection Television Problems
we are facing server problems please reply to me at coolguy4u_008@yahoo.com
don't worry i have found your part..
Apr 11, 2008 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
