Question about Whirlpool WRS342FIAB Black 22.0 Cu Ft Refrigerator Side-by-Side Freezer, Energy Star
Whirlpool refrigerator Model WRS342FIAB - newly purchased: I can get water from source to refrigerator, but cannot get water to come out of dispenser or to ice maker. I can see water/air in lines behi
Also, light at ice maker switch is blinking red.
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
  • 531 Answers
SOURCE: Ice maker not making ice -
check and see if the ice lever is down
Posted on Mar 31, 2009
From the water filter, where does the water tubing connect to?
Some have a connection behind kickplate at bottom front.
Oct 08, 2017 | Whirlpool Refrigerators
How do I get water flow back after replacing a Whirlpool water filter?
The replacement filter may have been installed backwards with the flow direction arrow point toward the source.
May 11, 2014 | Whirlpool Refrigerator Water Filter
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Can't get Ice/Water to dispense, I hooked-up the water hose from the water source to the refrigerator, turned-on the water, left the freezer bar in the "On" position, and unlocked the dispense. I verifed...
If this is a new purchase, you will have to depress the water dispenser lever long enough for the water to make it all the way through the system, including the water tank located inside the fresh food compartment.
Aug 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water stopped coming out of dispenser
Sounds like you may have had air enter your water line from an outside source such as the water company doing work. The air will stir up any sediment in the lines and it can clog strainers in various appliances. You have a strainer in your fridge water line just before the water inlet valve on the back of the fridge. Cut the water off under the sink or wherever the cut off is and take the line off from the valve and see if it's clogged up. Clean it out if it is and if you have any trouble with the washer it might have the same problem. The hot water lines aren't usually affected because the sediment will settle in the hot water tank. You ice maker should also be affected.
Apr 28, 2010 | Whirlpool GS6NBEXR Side by Side...
In-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water drips from the back of the refrigerator
Hello, unfortunately we are not certified technicians so we cannot advise you as to what may be causing the issue. We would recommend having a certified technician out to properly diagnose the Refrigerator. If you would like further assistance, please send your name, phone number, address, model/serial number and the date of which you purchased the appliance to Whirlpool_Reviews@Whirlpool.com.
Apr 18, 2017 | Whirlpool Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The water dispenser has stopped working!!!
could be a water solenoid problem (at the back portion where water from the sink enters ), or a micro switch in the dispenser area problem.
also, check if u have a water filter. could be clogged already.
tnx 4 using fixya,
drcool
Oct 09, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool WRS342FIAB Black 22.0 Cu Ft Refrigerator Side-by-Side Freezer, Energy Star Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
