Question about Sanyo PLC XU35 Multimedia Projector
How to reset lamp timer on vpl-hs60 - Sanyo PLC XU35 Multimedia Projector
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
Reset option killed the yellow warning to replace the bulb, but didn't reset timer...it's still showing 4,400. I bought new replacement lamp from www.electried.com, but it's showing dark. Is it the lamp or...
The projector's lamp cover might not be securly on or you might need a new one, or the projector has blown a fuse that can be replaced other wise it could be your projector but be sure to contact your sony dealer first.
Feb 09, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
How to reset lamp counter in Sony-VPL-ES3
To reset lamp timer in Sony VPL-ES3,
Press following keys on the remote control in following order for less than 5 seconds each,
RESET, <<, >>, ENTER
This will reset lamp timer.
Nov 26, 2009 | Sony VPL-ES3 Multimedia Projector
Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Apr 09, 2009 | Sony VPL-ES2 LCD Projector
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
RESET, <==, ==>, ENTER.
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Feb 11, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
I just replaced the lamp in my Sony projector with the recommended LMP-H130. Two problems. 1. I, my wife and my son all agree that the picture is not as bright as it was prior to replacement and 2. I...
this is our chat session, please rate it inappropriate it will spoil my rating.
vsurg: thanks
cmptrlink: welcome
vsurg: I purchased the bulb through electrified.com. OEM replacement for $249. Is there a difference between bulbs?
Read more cmptrlink: yeah the lamp should be purchased after proper specifing the device model, or the recommended lamp specified by the vendor
vsurg: It is the right lamp. Of that I am sure. The projector is a Sony VPL-HS51.
cmptrlink: hang on i will tell you the correct lamp number
vsurg: Manual says LMP-H130.
cmptrlink: is that the same one you got?
vsurg: Yes
cmptrlink: why dont you consult to a authorized sony service center.
cmptrlink: the lamp no. LMP-H130. is correct. but there must be some problem with the lamp or projector! is the lamp was packed when you got it?
cmptrlink: the projector normaly comes with 3 year warrenty
cmptrlink: To reset the lamp timer: 1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this
cmptrlink: is not clear in manual). 2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER. 3) Timer should now read '0'.
cmptrlink: hello
vsurg: I got disconnected
vsurg: how do i get back on?
cmptrlink: hello sir
cmptrlink: are you there?
vsurg: Iam back
vsurg: How do I get back to the live session?
vsurg: I think I figured it out. I am back
vsurg: Please respond. I can't keep this up much longer
vsurg: How do I get back to a live session please?
Jan 16, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
VPL-HS60 Scene Dimming
Hi 3mad
This is quite a sticky one as this could either be the lamp or the Ballast ( lamp's powersupply )
And the bad thing is that the only way to be certain , would be to first replace the lamp and if this continues the Ballast as well.
I would suggest you to replace the lamp first , as this is never a waste , you could always keep it as a spare and 99% of the time it is the lamp will give this kind of problem.
Good luck and thanks for using Fixya !
May 21, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sony hs 51 projector problem
open the lamp cover if the power indication comes and check the connectors of cover sensors. also check and service the complete unit by disassembling all the cards & connectors. Lamp life also has to check.
Mar 21, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
Jan 14, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Sanyo PLC XU35 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
