Question about Garden
Putting new battery in black & decker cm500
I can't get the plastic cover to fit back on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
There our three different battery for black and decker the batteries do not interchange you probably got the wrong battery are get the smaller battery black decker battery our maybe go battery plus they will get you the right battery
Posted on Jul 07, 2014
How to replace battery on a black and decker cordless trimmer
  • Remove battery pack
  • Unscrew screws with Philips #2 to remove cover plate
  • Suggest you take picture with smartphone / digital camera of layout before removing battery, so you can easily pit back correct
  • Remove battery - you can easily get a replacement at Batteries & Bulbs or online.
  • Replace battery
  • Reassemble per picture
  • Put cover back on
  • You should be good to go
Jun 04, 2014 | Black & Decker Cst2000 12 - Volt Cordless...
Problem putting handle on mowe
Check The Fuse Underneath the battery box.
Jun 01, 2013 | Garden
Fit new chain to gk1000 black & decker alligator
lay the machine on its side motor side facing downwards undo the 2 nuts that hold the cover on then remove cover, pull the chain bar backwards the remove the chain replace the chain making sure that the chain cuts in a clockwise direction then put cover back on, put nuts back on finger tight tension the blade by turning the flat bladed screw clock wise then tighten the 2 nuts up full..
Dec 01, 2010 | Black & Decker Garden
How do I attach the machine to the wall charger when the protective cover prevents it fitting properly to the wall. Sticks out below putting it at an angle to not fit into the charger. Do I have to remove...
If you can't make the charger fit while the battery is attached to the trimmer, you can remove the battery pack (the whole black handle assembly) by pressing in the two orange tabs (one on each side) and sliding the battery pack forward off of the trimmer. Then you can plug the charger in and charge the battery wherever you want. It can be a struggle to remove the battery pack, but it does come off.
Hope that helps.
Jul 17, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Battery to fit Black & Decker CST20000 Grasshog weed eater. Where can I buy just the battery or battery pack?
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
May 20, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
I just wonder i can still get battery charger for black decker cordless drill mode is ps3600 because my old one is not working i need new one
Menards or Home Depot sell chargers for cordless power tools. Pricey, but obviously needed. The Black & Decker model battery you own should fit the newest chargers no problem.
Aug 22, 2009 | Drills
Grass Shears Gear Assembly (Black & Decker brand)
My neighbor found where the washer went.....right on top of the big plastic white gear.
Aug 14, 2009 | Black & Decker Garden
Black and Decker battery charger does not work.
Open it and look for a fuse, then go buy a new one (my Ryobi charger didn't have a fuse)
Mar 29, 2009 | Black & Decker Black And Decker FS24C...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
