Question about Honda Water Pump Impeller Outboard 35, 40, 45, 50 Hp 18-3248 19210-zv5-003
Manual 50
I have 2005 50hp Honda.I replaced the empella and the pump great until I speed up to 10 - 12 knots. the water from the pump slows down and the alarm goes off. engin shuts down. What is going on? I can cruze at 7 knots without heating up.
  • 1 more comment
  • James McCall
    James McCall Apr 22, 2014
    I can run the HONDA 50 at full speed in nutral and it does not cut off or heat up., Any body out there ever have this problem or have an answer . jmc
  • James McCall
    James McCall Jul 21, 2014
    The cap of the water pump was leaking . I replaced it ( new cap)
  • James McCall
    Slideing the cap down is important, make sure when the cap is slid down ,the impella should be already in the cap and turn anticlockwise as it is put in place. Honda 50 : anticlockwise
emjem74
  • 162 Answers
SOURCE: 2005 Honda Civic No heat at idle but have heat
sounds like a circulatory problem. at the back of your engine compartment there should be two pipes connecting your matrix to your water system. it used to be common practise that when your matrix went to just connect them together and bypass as the dashboard has to come out to repair.
Posted on Feb 25, 2009
SOURCE: 1995 honda civic, while driving engine gets hot & cold?
I used to have this problem too on my 95 Honda Civic EX. It would get hot then it would cool down when I stopped. I replaced the thermostat and it took care of the problem. I am not a mechanic but it was real easy to change out. I bought it at Auto Zone and they even gave instructions on how to replace it. Also don't forget to buy the new seal for it. Hope this helps.
Posted on Mar 15, 2009
  • 57 Answers
SOURCE: 98 honda shutts off and will not start until cooled off
you say the engine shuts down when it gets hot if it runs rough before doing so it could be the coolant temperature sensor allowing the engine to  overfuel  if the engine cuts out in a couple of seconds but sounds smooth it could be the fuel pump , if it cuts out instantly its electrical.
Posted on Mar 28, 2009
  • 6 Answers
SOURCE: Check engine light went on: 98 Honda Accord car
cooling liquid get in contact with gas because o broken cylinder head gasket
Posted on May 17, 2009
SOURCE: 1977 Honda GL1000 Goldwing. I replaced the water
I have a few 1977 GL-1000 bikes.
I thought one was overheating but it turned out that the 9 volt regulator was fried and was putting 12 volts to the temperature gauge. Temperature was really OK. The fan switch is probably not lying
Posted on Aug 06, 2009
Catalog repair honda spacy 100ccThere is no speed while driving for the bike is slow
Hi, Sadek and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://www.quora.com/Why-does-my-bikes-engine-stop-when-it-is-slowed-down
Why is my motorcycle losing power when accelerating
Honda Zoomer Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Spacy Owner Manual
Mar 21, 2017 | Honda Motorcycles
Is there a speed limit for airplanes?
There are some speed limits for certain types of airspace. Airliners are always in contact with air traffic control and in order to keep the required separation of aircraft sometimes the controllers will ask the pilot to maintain an airspeed. More than likely you experienced a slowdown while your plane was beginning an approach, During approach controllers have to maintain specific spacing between aircraft and often must slow them down behind slower aircraft. Your plane very likely was slowing down from approx 570 knots to 250 knots or less for the approach.
Jan 04, 2017 | Aircrafts
R reg toyota previa over heats. had new pressure cap n tested the head gasket so both of them are fine. is it likely to be the water pump? as its worse wen Im startin n stopping but seems fine wen Im...
It appears that you have a viscous fan hub driving the fan or should I say failing to drive the fan. The fix is to replace it . If you have electric fans then there is a problem in the temp sensor system and the fans are not cutting in on temperature The problem you state is indicated by the fact that when driving there is sufficient air through the radiator to remove the heat from the radiator ..but when driving slow there is no air flow because the fan is not drawing air through the radiator and the temperature climbs until over heat is reached . Typical indicators of fan speed problem is overheating at stop sign/lights, slow heavy traffic driving, slow up hill driving, and rapid cool down as road speed is increased , the faster the speed the cooler the motor
May 15, 2014 | Cars & Trucks
Grinding Noise when I drive
you probably need brakes and/or a wheel bearing.
Mar 05, 2013 | 2005 Honda Accord
How to change water pump 1999 honda cbr
Hi, undo the water pipes, catching the water to save coolant spilling onto the floor and contaminating the tyres, remove the pipes by pulling them gently until they are removed, undo the pump fixing bolts and gently pull the pump away from the engine, replace the pump using a smear of oil on the pump oring tighten the pump bolts evenly replace the water pipes and refresh the coolant, checking the level again after cooling down
Oct 06, 2011 | 1999 Honda CBR 600 F(4)X
Overheating with a new thermostat, new radiator. 1997 3000GT
may need a new water pump butr sounds like the empella just needs replaced
Aug 22, 2011 | 1997 Mitsubishi 3000GT
2002 montana the temp gauge stays in the middle but when i drive it and come to a stop i lose heat i replaced the thermostat and water pump flushed the system refilled and purged what eles could be wrong
your heater core may be partially clogged up, when you come to stop the engine speed slow down and so does the water pump. therefore you don't have enough flow until you hit the gas and the engine rev up again
Feb 26, 2010 | 2002 Pontiac Montana
OVERHEATING, engine temperature rises up?
think impeller drive is slipping on the drive in the water pump
Dec 31, 2009 | 2000 Honda Civic
Washer will not spin properly
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 06, 2009 | Washing Machines
BMW 328I No Heat ..Cold air only
water pump may be the way to test take off cap when cald hold reves see if water flys out if so ok if not water pump maybe on the way out
Jan 16, 2009 | 1999 BMW 328 Series
Honda Water Pump Impeller Outboard 35, 40, 45, 50 Hp 18-3248 19210-zv5-003 Logo
42 people viewed this question
Top Honda Plumbing Experts
Matt Olenzek
Matt Olenzek
Tony Crow
JonSnell Electronic
JonSnell Electronic
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
