Question about Ultrex 2-in-1 (9qt) 8-Quart
Manual Need to know when if water is added to outer crick for slow cooking on low.
I have never had a slow cooker in my life and found this one in a garage sale without the manual. How does it work?
Yes you can use any cheaper cuts of meat or chicken and yes less liquid is used in slow cookers. add hard veges n use green veges for end of cooking time. cook for 6 or 8 hrs on low. Yeilds ecellent results. Find slow cooker books for great meals n desserts. I use mine every week.
Apr 22, 2015 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Where can I find a consul manual needed for my old model slow cooker?
    Go online, to "www.( product name.com/manual model number ) ,
    Or something to thatefeect, also try ebay..often a person might post a <Product manual> for a free or $1 or $ 2... but first try the online tech support for you CrockPot...the other thing you might what to try is to go to the local Librart and check out a cook on cooking with a crock pot..this a fairly genralized area of cooking..it is not rocket-sceince..
    Washed beans take 4hours on high and adding water and flavor with a reduced heat they are good all day long for the family to enjoy at will on a cool-winters day.
    Good Luck
    Jul 28, 2014 | Crock Pots & Slow Cookers
    Need a manual for the corningware sc60
    The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
    Nov 28, 2009 | CorningWare SC60 Slow Cooker
    Ronson slow cooker don't know which is high or low
    on setting 1 (low),the slow cooker can operate all day and night if required
    when set to 2 (high) it is very much like a covered pot on the stove.food will cook in half the required time
    AUTO the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature,then switches to 1(low) and maintains a constant slow cooking temperature.Auto is ideal for someone who is leaving the house for the day 8-9 hours please feel free to share this information.If you have any more ? please fell free to contact me.
    bianca
    Jun 12, 2009 | Crock Pots & Slow Cookers
    I need a manual for a west bend 3qt 84114 slow cooker
    what do you need to know, they are so basic that I don't even think they have a manual. Very strate forward . Check out some cook books, or a crock pot cook book, that will solve you needs, and teach you to cook at the same time. Happy cooking.
    Apr 11, 2009 | Crock Pots & Slow Cookers
    Lost Manual - not sure which is high or low
    Hi. I'm a Ronson Service Centre.
    I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
    On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
    When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
    When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
    “Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
    Mar 15, 2009 | Crock Pots & Slow Cookers
    This is ridiculous. I just want the manual for the corningware sc 60 slow cooker so I can print it out. Why all the runaround. This should be simple
    1. Turn off and unplug the slow cooker first.
    2. Plug it in, but (yes, I know this sounds crazy) DO NOT turn it on.
    3. Set your cook time and it will automatically set the temperature based on the cook time.
    he The magic number is 7. Anything set for less than 7 hours will be cooked on high. Selecting a time more than 7 hours will result in cooking on low. Once the cook time has expired the cooker will automatically switch itself to warm until you turn it off. Follow these steps and you should be able to enjoy your cooker again! I don't know who was in charge of this type of setup for programming but they should be demoted at least - no wonder there are so many questions online about this one. Sure hope this helps you!
    D
    D
    Nov 29, 2008 | CorningWare SC60 Slow Cooker
    To add water or not to add water????
    Slow cookers do not need water in the base unit to cook the food in the ceramic insert. The ceramic insert gets hot from the base and cooks the food. Here is a good guide to cooking with a slow cooker. enjoy
    http://busycooks.about.com/library/print02/ncrockpot101.htm
    Dec 06, 2007 | Select Brands SC-25 2.5-Quart
    Ultrex 2-in-1 (9qt) 8-Quart Logo
    154 people viewed this question
    Top Ultrex Crock Pots & Slow Cookers Experts
    ray gallant
    Tom Chichester
    Are you an Ultrex Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
