Cars & Trucks Logo
d
dee perez Posted on Apr 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hpw do I remove 216 motor from my 1950 fleetline
Albert Coats
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Chevrolet Expert 125 Answers
  • Posted on Nov 15, 2014
Albert Coats
Chevrolet Expert
Level 2:
New Friend:
Greenhorn:
Answers
125
Questions
Helped
27850
Points
197
First thing to do is remove the hood,next disconnect one of the battery cables,( I assume you have a chain hoist or a portable hoist)
if you don't have you can rent one for so much a day. make sure you put pulling chains on the motor, you will probably have to take off the valve cover when you get that done remove two head bolts, one at hook the chains through the head bolts, now make the chains are taught front of the motor and one at the back. now on each side of the motor (lower part of motor) you will fine the motor mounts, make sure you don't have the chains to tight just snug, when you have the motor mounts bolt loose, not taken clear out. You will to disconnect the drive shaft from the truck, I think it will a 7/16 or a 1/2 inch bolts you have to remove, another thing , have a pan ready because the transmission oil will leak out the tail of it. ok here we go,find the tranny mounts and remove the bolts(be darn careful under there. something I did not mention before, make sure you remove the radiator and of course all the wires and fuel lines oil lines,etc.I hoped I helped have a happy thanksgiving.
1952 chevy fleetline deluxe heater core removal diagram
It's been a few years, but isn't it behind a panel that is behind the fresh air duct under the hood? Once you get the duct out of the way you should see a plate that is bolted to the inner fender. Get that plate off and it should just slide right out.
1helpful
What is the engine power of the chevrolet fleetline of the year 1947 ?
i THINK i ANSWERED this already.
I6 3548 cc ' 216.5 cu in. ' 3.5 L.
90 BHP (66.24 KW) @ 3300 RPM
170 Ft-Lbs (230 NM) @ 1200 RPM
Bore : 3.5 in ' 89 mm.
Stroke : 3.8 in ' 95 mm.
1 barrel carburetor
Transmission:
3 Manual
1helpful
3helpful
2answers
Where is number one spark plug wire on dist for 1950 gmc 216 ci
Since distributor may have been moved, best is to turn engine with #1 plug out until you get to TDC compression stroke on #1, then remove dist cap to see where rotor is pointing.
The freeze plugs on my 1950 216 cubic inch chevy seem impossible to get out . after twisting cutting and turning i thought this cant be right almost seems like they are part of the engine block .i then...
freeze plugs can be a pain to remove, i used to drill and install a metal screw to pry it out, careful not to scratch the surface on the block, us a slight bit of sealer with the new one
1helpful
Wiring diagram to 1950 Chevy V6 engine for dad.
they had straight 6 engines back the which was a 216 cubic inch motor
Hpw do I install an ac/heat blower unit
disconnect the negative battery cable
Disconnect wiring harness and rubber tube to motor. Then remove the 3 screws and remove motor and cage
Use a vice grips to put on cage axle and remove the cage and axle and place on new motor and reinstall
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
