Question about Whirlpool Dishwashers
No top rack cycle - Whirlpool Dishwashers
  • Whirlpool Master
  • 3,247 Answers
The top rack cycle depends on water getting to the top wash arm.
Usually problems can occur if this or the water tubes feeding it are not clean. It will help look at the problem in more detail if you provide the full model number in the comments field.
Posted on Apr 25, 2014
How do I remove the top rack?
Good Morning friend, thank you for your post!
Based off what your have described you need assistance in removing the top rack off your Electrolux dishwasher. In order to remove the top rack you would need to remove the caps from your rail and you should be able to pull it up and out. I hope this information is helpful. -Matt
Feb 21, 2015 | Electrolux EWDW6505GS Fully Integrated...
Quite Partner 2 no top rack wash cycle
The top rack in your dishwasher not working, the recirculate pump may be clog or Gump up with food broken glass and plastic check sump,
Apr 20, 2014 | Whirlpool Dishwashers
Top rack not getting clean on Normal Cycle
Empty the dishwasher. Look at the 2 rotating plastic arms in it (like 2 bladed windmills) spin each one, do they move freely without hitting anything? If so remove the top one (its a press on fit) the look inside it with a torch, is there any debris or dirt inside it blocking it? Water has to flow inside it or it will not spin, and top rack gets no water spray.
Dec 20, 2013 | Dishwashers
Top (upper rack) of dishwasher does not wash. bottom does mediocre job
Make sure top rack is backed up into water entry in back of diswasher. Also check to make sure holes are not plugged in rotating wash arm. You may have to wash your dishwasher..take out the racks and look to see if they have food gunked up on them, if so wash them off in the sink. Take out the top rack clips and wash the rails inside the tub if they are dirty. You can use a squirt bottle with warm water. Do this after you run a rinse cycle so that dried food gunk is softer. There are alot of places in this machine for food to stick then resurface later. you may try also adding vinegar and baking soda to a rinse cycle and then leaving in it soak before restarting it.
Feb 10, 2011 | KitchenAid Dishwashers
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Does not remove all food some residue remains after wash cycle
check and make sure that you are getting water too the top rack place a cup or mug upright in the top rack turn the dishywasher on for about 2 minutes you should a least have filled the cup up half way if not to the top. if you are not getting water to the top rack check to make sure that you have enough water in the unit. also before starting the wash you want to point the wash arm in the same direction to make sure that they are turning. Do they turn? when you are finished with a cycle do you see steam or is it cold inside. let me know what you find.
Sep 07, 2009 | Kenmore Dishwashers
Top rack washer arm isn't spinning and therefore not cleaning dishes in top rack, bottom works fine
You can replace the whole top assembly. And before you run the cycles again, try putting a cup of Tang (dry) orange juice through the cycle without any dishes or get some Dishwasher Magic and you'll have a sparkling new dishwasher once again! hope this helps you!
Aug 14, 2009 | Dishwashers
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwashers Logo
124 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
