Question about Whirlpool Dishwashers
Quite Partner 2 no top rack wash cycle
Quite Partner 2 DU1301XTVQ2 No top rack wash cycle never engages. Only bottom wash. No clogs. Reset panel. Is it the control board?
    New Friend:
The top rack in your dishwasher not working, the recirculate pump may be clog or Gump up with food broken glass and plastic check sump,
Posted on Apr 25, 2014
wiringlunati
  • 576 Answers
SOURCE: whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Posted on Nov 25, 2009
kram26
  • 544 Answers
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Posted on Mar 18, 2009
ve3wtj
  • 147 Answers
SOURCE: top rack not cleaning
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Posted on Sep 17, 2008
  • 949 Answers
SOURCE: quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 25, 2010
Testimonial: "Very helpful, the link with step by step instructions was fabulous!!! Thank you so much, I was almost ready to go buy a new dishwasher."
SOURCE: I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Posted on Aug 15, 2010
Hi I have a Hobart amx-16 quite an old machine now... when I pull down hood to start cycle, indicator comes up FIL.... during its cycle.... any advice please? Is there a reset function
This sounds like the dishwasher's filter might be clogged. It should be located under the bottom dish rack. It's fairly easy to disassemble. Just remove it and clean it out. Also, check under the filter to make sure there isn't any more debris and/or lime deposits there as well.
I hope this helps! :)
Jun 11, 2014 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Our Whirlpool Quiet Partner III cleans the bottom rack fine, but the top rack does not seem to have any water pressure and thereby does not clean. Any solutions?
two things that you need to check one is the water level in the machine when it has completed it fill cycle.low water level will cause this issue with imporper cleaning.
make sure the spray arm is not clogged in any way.
the other is simply replace the main wash motor
Mar 09, 2010 | Dishwashers
Have a hoover hed6612 dishwasher just over a year old, it pre rinses and part washes and then doesnt move to the next rinse cycle instead it stops and beeps continuously with the prerinse and wash buttons...
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Dec 06, 2009 | Hoover Dishwashers
Whirlpool du1055xtsq 3 not cleaning top rack of
Nov 25, 2009 | Whirlpool Dishwashers
HI,
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
Top rack not cleaning
Sep 17, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwashers Logo
60 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
