Where do i get a new battery and where do i put it
  • kakima Apr 20, 2014
    Battery for what make and model player?
  • 3,904 Answers
You will have to carefully separate the case to get to the battery. Once in you can identify the battery and get it at Batteries Plus.
Posted on Apr 20, 2014
Why does the charger kill a new battery in 1 minute?
That typically happens if the charger is shorted or the battery is inserted backwards. Putting energy into some batteries that are not designed to be rechargable will destroyh them.
Nov 29, 2014 | Audio Players & Recorders
Put in a new battery, it was dead the next morning, whats using the power
I was having the same issue with my car not sure if yours is the same issue but check out the alternator amp fuse
Feb 22, 2013 | 1990 Ford F250
Battery replacement eventhough new batteries put in
is the new rechargeable battery charged full? if yes your battery isn't compatible with the camera.(http://www.my-batteries.com/digital-camera-batteries/sony-np-fr1.htm)
Aug 06, 2012 | Canon PowerShot SX100 IS Digital Camera
JUST PURCHASED NEW CAMERA, PUT NEW BATTERIES IN AND AFTER TAKING JUST A FEW PICS, BATTERY LOW INDICATOR CAME ON AND SAYS IT NEEDS NEW BATTERIES. PUT NEW ONES IN AND AGAIN, BATTERY LOW INDICATOR CAME ON. ...
yes, The Flash mode consumes LOT of power, thats why it needs lot of batteries, use " rechargable batteries", or use camera without FLASH, and use GOOD QUALITY battaries
Jan 22, 2011 | Canon PowerShot SX100 IS Digital Camera
1989 Bronco: 89 ford bronco i put a new starter new battery new...
Check the battery cables for corrosion near the battery terminal end. Sometimes it builds up under the rubber insulation. I would check the ground wire that runs from the battery to the engine block.
May 16, 2010 | 1989 Ford Bronco
Changed battery on 2003 toyota echo but when i put the new one in and start i have no power the new battery is fully charged 12.7 volts put old battery back in car starts is there a special procedure for...
Check the new battery posts(connections if side terminal) alot of the battery companies put a protective coating on and it has to be removed. Use wire brush or sandpaper to clean them and you should be fine.
Dec 03, 2009 | 2001 Toyota Echo
I put in a new battery. When I switch to
New batteries should always be charged before the first use as they loose charge lying idle in stores. All batteries do.
Sep 17, 2009 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
PUT BAD GAS IN AND NOW CAR DOESN'T WANT TO START
sounds like alternater, is on its way out, if it is not charging or over charging, it can drain your battery dead.
Aug 06, 2009 | 1996 Chevrolet Blazer
Car will not recognize new battery
i put a new battery in mine and was told to put in the new battery and then get in the car with door shut and turn key to on position for about 90 seconds, this worked for me, mabey it will work for you, if your battery is still hooked up you should first unhook it for a couple minutes then reconnect the battery and follow procedure. hope this helps
Jan 01, 2009 | 1997 Hyundai Sonata
23 people viewed this question
 Grubhead
Grubhead
